Aynone having/had HEI failure?
Old Mar 12, 2005 | 07:07 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Aynone having/had HEI failure?
I have had two H.E.I. modules fail. Did I have a bad luck of the draw or is there a cause for this? Happened about 12 months appart with just 1,000 miles.
Thanks!
Old Mar 12, 2005 | 08:33 PM
Glassbowtie77's Avatar
Glassbowtie77
When you replaced the module did you use the lube they give you with it? It is designed to keep the module from overheating, just a thought.
