Steps to replace the rear leaf spring
Old Mar 12, 2005 | 07:08 PM
Porch40's Avatar
Porch40
Default Steps to replace the rear leaf spring
Could someone tell me the steps to replace the rear leaf spring ? I'm replacing it with a standard steel spring. The 'Weekend Corvette Projects' book I have seems to have left out a few crucial steps unless I'm missing something. It's for a 74.
Thanks for your help,
Scott
Old Mar 12, 2005 | 08:31 PM
68/70Vette's Avatar
68/70Vette
There's been so many postings about this subject. You should probably try a "Search." Also, if you're going to be reworking your suspension, you really should buy Van Steel's videos. (a Forum sponsor.)
Anyhow, for loosening the rear spring, the main thought is to be very careful. Of course you remove the wheel. Then use a floor jack. positioned against the extreme end of the spring, and jack the spring up until there's no tension on the trailing arm bolt. Now you can remove the trailing arm bolt cotter pin and unscrew the castle nut. HOWEVER...there is a danger at the stage associated with unscrewing the castle nut. If somethings breaks loose with the spring, that you've just deflected with the floor jack, the spring can do a lot of damage. When I removed my castle nut, I positioned my hands and tools such that if for some reason the floor jack suddenly failed, I wouldn't be hurt by the explosive deflection. If the spring gets loose instantaneously, it would be something like an explosion. If your castle nut is pretty much "welded" to the trailing arm bolt due to corrosion, I think you should take a "C" clamp and clamp it to the spring. Next take a chain and wrap the chain around the spring and the differential crossmember. The C clamp will prevent the chain from sliding inboard. The chain will hold the spring in position while you can work getting the rusted bolt loose. However, my opinion, if the bolt/castle nut is corroded don't try too hard to unscrew it, if it's hard to get off then simply cut it off.
If you're going to do this kind of work on your car, hopefully you can get an air compressor and air tools. Air tools are really so effective with suspension work. An air powered cut off tool will cut this 9/16 inch bolt in maybe 2 minutes! I have an air impact wrench, and for working with suspension parts, this thing is just magic.
Old Mar 12, 2005 | 09:34 PM
Yellow6t7's Avatar
Yellow6t7
Just read your Chassis Service Manual. It gives you the simple process.
Don't take any short cuts. This is a dangerous project. Not difficult, just dangerous.
To Steps to replace the rear leaf spring
