Engine dress up?
Old Mar 13, 2005 | 10:41 AM
meangreenie's Avatar
meangreenie
Default Engine dress up?
Have a '73 coupe w/ a stock L48. At this point I don't really feel a need for big hp gains, but a little more would be nice. Just want to be proud of the appearance when I lift the hood, and I want it to sound nice too. I really love the sound of a lumpy idle! Of course, I don't want the engine to run poorly because of using a higher lift cam without making other changes to get the most out of the cam.
I'm thinking of a Demon carb 650-750, cam, dual plane aluminum intake, aluminum valve covers, and just powder coating the heads aluminum.
Really don't know what I should do on the exhaust end? Maybe just powder coat the exhaust manifolds aluminum & different mufflers? Or would I want to go with headers, and an all new exhaust run?
Any thoughts on specific components which would work well together? And would give me the look and sound I'm after? I'm looking to spend around $1500 or so. Thanks for any advise & suggestions!
This picture was taken and posted previously by another form member from a car show. I'm just posting it here, because this is the basic look/color scheme I love.
Old Mar 13, 2005 | 11:21 AM
70_Shark's Avatar
70_Shark
meangreenie,
I'm not getting any pic. Just the anglefire seal. Please check your link, or is it me?
-Dan
Old Mar 13, 2005 | 12:09 PM
meangreenie
Originally Posted by 70_Shark
meangreenie,
-Dan
It's coming up for me on the CF?
Old Mar 13, 2005 | 12:18 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
There you go.
Old Mar 13, 2005 | 12:27 PM
meangreenie
To keep it a little more simple...Should I just invest a little more, and go with a crate engine. Then add the items that finish the look I desire? Keeping in mind their recommendations for good performance.
Old Mar 13, 2005 | 01:08 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Old Mar 13, 2005 | 08:24 PM
Red73's Avatar
Red73
Originally Posted by yellow 72
That would be my choice.
Old Mar 13, 2005 | 08:45 PM
James B's Avatar
James B
650 CFM should be fine. I personaly would not go bigger than that. 750 is realy pushing it for the L-48 IMO.
James
Old Mar 13, 2005 | 09:44 PM
page62's Avatar
page62
Ceramic coating is preferable to powder coating in high heat applications. On the exhaust manifolds, it helps reduce heat radiation considerably!
Plus it helped there was a ceramic coating shop just up the road...
Old Mar 13, 2005 | 09:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
your $1500 will get eaten up fast....450 for speeddemon and fuel line, 150 new distributor or 80 to rebuild your own, 130 for intake, 200 for valve covers....
[IMG][/IMG]
[IMG][/IMG]
Old Mar 13, 2005 | 09:51 PM
oregonsharkman's Avatar
oregonsharkman
heres mine............
Old Mar 13, 2005 | 10:00 PM
bobs77vet's Avatar
bobs77vet
sweet are those edelbrock heads also????
Old Mar 13, 2005 | 10:11 PM
joe73vette's Avatar
joe73vette
I'd keep the q-jet and get a performer intake manifold. Paint/coat the factory cowl induction air filter silver, it works better than any aftermarket filter. I like the LT-1 valve covers, but there are dozens of good looking ones out there. GM makes a cool angular set. The L48 heads and cam are very weak, don't put any money in them. I just upgraded mine, can't wait to drive it. If you get aftermarket heads you can also use center bolt valve covers. Headers will give more wow factor when you lift the hood, get ceramic coated for the look and sound you are after. $1500 goes fast, don't spend it foolishly. Joe
Old Mar 13, 2005 | 10:14 PM
oregonsharkman
yup......new rpm heads with revised chamber.....
Old Mar 13, 2005 | 10:26 PM
bobs77vet's Avatar
bobs77vet
i hope they threw in a free t shirt or 2 with that whole set up!!!!
Old Mar 13, 2005 | 10:32 PM
carl a's Avatar
carl a
heres my 73's engine compartment--jet hot coated manifolds and cooling fan----------
Old Mar 13, 2005 | 10:37 PM
oregonsharkman
No, but i bought myself a beer....
Old Mar 14, 2005 | 05:32 AM
meangreenie
Nice looking engines guys! And thanks for the suggestions.
Old Mar 14, 2005 | 06:30 AM
Graemeinvette's Avatar
Graemeinvette
Coming in late here because of the time difference, but I went the crate engine route taking up their option of the serpentine pulley system etc.
To Engine dress up?
