One last 5 speed problem.... reverse lights.?
Old Mar 13, 2005 | 07:50 PM
dfdsmokeater's Avatar
dfdsmokeater
Cruising
Default One last 5 speed problem.... reverse lights.?
How did you guys get these connections to be reliable? they are weak at best for me. anyone find something that works better??? pictures of your solution? pictires of your reliable installation?? this looks like the very last thing i need to get done!!!!! YEA!! Too bad its snowing....
trav
ps- thanks once more time!
Old Mar 14, 2005 | 06:55 AM
Gordonm's Avatar
Gordonm
If you are talking about the Keisler 5 speed the yare lousy. Mine ended up on my headers while at the strip. Kind of embarrasing coming back smoking after a run of burnt wires. I actually soldered two wires on the studs and put a connecter about 4 inches down stream of the switch so I can remove it. It has held up for a year now. Not the easiest thing to solder but it worked. I then did my best to put some shrink wrap on it to keep out and debris.
