Does anybody know if this engine will fit under the hood of a 72 Vette
with a Turbo 2 hood. I bought the car unassembled so I no way of measuring the original hood clearance. Thanks for any help. http://www.sdpc2000.com/catalog/3508...e-Assembly.htm
This is probably not going to be much help, but the Ramjet 502 needed an additional 1.25" of clearence with the space that an L-88 hood could provide without the air chamber. It measured 11" from the front engine short block china wall to the top of the intake.
The RamJet 350 GM drawing shows 9.75" for that same dimension on a small block. Assuming the SB sits just as high as the BB, (which I doubt) then it just fits with no free space.
I don't know how the Turbo 2 hood compares to the L-88, but I bet it doesn't provide any more clearance??????
Yep, I've got pictures somewhere, I'll send you a separate email since I don't know how to post them within the text. I'll either find them or take others.
I got your email, Thanks. To me this looks like good/economical/easiest way to get into a fuel injected crate engine that looks like it could have came out that way
The vette had no engine so I need the who package and since this is for my daughter 350HP and 400 Torque will be plenty. See our saga/story http://forums.corvetteforum.com/showthread.php?t=966688
Good luck on that fuel injection, that more than I can Handle now
I ended up wiring my Ramjet 350 to a GM ECM 1227730, it always ran fine, but it also always smelled rich. I ended up burning my own chip with a laptop.
After checking out the prices for MEFI reprogramming I figured I'd try, so I spent the money on a Autoprom (chip reader/write/emulator)....I'm glad I did it.....learned a lot too.
The new MEFI-4 that comes with the new ramjet should be better, however I don't know if it comes with VSS.
You can buy the ramjet intake and throttle, all the other parts are generic GM TPI sensors and make your own.
To my ramjet system I added a VSS and IAT sensor...I think that's all; well, I had to wire it into the ECM, but you can use a generic 1990-92 Camaro V8 schematic.
That's what I would do if I had to do it over again.
