Rear Wheel Camber
Old Mar 14, 2005 | 04:19 PM
1974slcvette's Avatar
1974slcvette
Default Rear Wheel Camber
I just purchased a 1974 Corvette, but on driving it home my wife, who was following me, noticed some visual negative rear wheel camber. Where should I start. Would this be my shocks, the leaf spring, or something more serious? The negative camber is exactly the same on both rear wheels.
Thanks for any help - suggestions,
Mark
Old Mar 14, 2005 | 04:40 PM
tippi77's Avatar
tippi77
Not a major problem. Wheels shouldnt have excessive negative camber but should have a slight amount. - 0.30/30.
The camber is adjusted by the strut rods which run parallel and above your driveshafts connecting the base of the spindle support arm (where the shocks mount) to the bracket assembly which bolts directly to the Differential carrier assembly.
You may have worn bushings at either end of the strut rods. If so remove them and replace.The shock mounting bracket is a BITCH to get out. It may be that your camber bolts are loose allowing the strut rods to move out of alignment or just that your alignment is out.
According to the factory assembly manual set as follows.
1. Loosely assemble (finger tight) cams and attaching parts at inboard end of strut.
2 Rotate cam to obtain specified camber.
3.Hold camber setings and torque nut with rear suspension at D height of 2.21 in. (torque setting 55-75 FT)
"D height" is the height between the centreline of the outside strut arm mounting hole to the centre line of the inboard strut arm mounting hole.
This can be acheived by jacking up your trailing arm to the specified height. Dont let it just hang down because your alignment will be out.
Hope this helps. If u want I can scan the pages and send direct to your e mail.
Let me know at Kaycee@paradise.net.nz
