Problem With Priming The Engine With Oil
Old Mar 15, 2005 | 10:39 PM
mandm1200's Avatar
mandm1200
Default Problem With Priming The Engine With Oil
I have just about finished assembling my engine. I wanted to ensure I was getting oil flowing through the push rods and to also pump up the lifters to set the lash (hdy lifters). I made up an oil priming tool and spun the oil pump for several minutes several times. I am getting a trickle of oil coming out of the rockers on the odd side but not getting anything from the even side. The lifters on the even side have not pumped up either. Is there something wrong or will they pump up after firing the engine? Any suggestions would be appreciated.
Old Mar 15, 2005 | 10:50 PM
joe73vette's Avatar
joe73vette
Try rotating the crankshaft one turn and priming it again. Then rotate it another turn to get back to #1 firing to install the distributor. Joe
Old Mar 15, 2005 | 11:02 PM
Jclgodale3's Avatar
Jclgodale3
and keep pumping...it will start coming out
Old Mar 15, 2005 | 11:07 PM
sssuch's Avatar
sssuch
Is your priming tool just a shaft or did you make out of an old distributor? The reason I ask is the distributor body is needed to seal the oil passage that leads to the other bank of lifters. Stan
Old Mar 15, 2005 | 11:13 PM
robert kirk's Avatar
robert kirk
Old Mar 15, 2005 | 11:15 PM
69monzaredbigblock's Avatar
69monzaredbigblock
Are you sure you want to pump up the lifters prior to adjusting? Some require the lifters to be unpumped up to adjust.
Old Mar 15, 2005 | 11:20 PM
mandm1200's Avatar
mandm1200
Stan:
That may be the issue. I made one out of a piece of steel to go into the slot of the oli pump shaft. I used a steel sleeve to keep it on the shaft. I looked at the Mr. Gasket primer online and that is essentailly what they sell. I would have purchased one, but no one sells them locally and I wanted to button up the engine without waiting a couple of days to order one.
I rotated the engine several times thinking that would help.
Is if safe to say that things are normal? Should I drop in the distributor and then crank it over with the starter (when it arrives)? Or will I have to crank with the starter to long and cause any damage? Should I just order in priming tool that seals the oil passage?
Old Mar 15, 2005 | 11:35 PM
joe73vette's Avatar
joe73vette
You can make a priming tool out of an old distributor - remove all the top stuff and grind off the gear teeth. Joe
Old Mar 16, 2005 | 01:01 AM
griffths's Avatar
griffths
There is an article in the March edition of Corvette Fever on pages 66 and 67 that explains how to turn a distributor into a priming tool. Nothing more than Joe73 says but there are a few pictures to go along with the words.
Regards,
Jay
Old Mar 16, 2005 | 07:34 AM
sssuch's Avatar
sssuch
Originally Posted by mandm1200
Stan:
I perfer to bring it up to pressure for a good 5 minutes or so , Its probably not really necessary but it makes me feel good. Since your pump and filter are allready primed good I would go ahead and install the distributor , hook everything up but leave out the sparkplugs then crank it til you see oil pressure install the plugs and start it.
Old Mar 16, 2005 | 12:10 PM
AV8RSVT's Avatar
AV8RSVT
Go to A salvage yard buy an old distributor if you dont have one. There is A pin that holds the gear on "just remove the pin" slide the gear off. then take the guts out of the upper portion of the distributor. Piece of cake!! This will get oil pumping into both sides for you. This is what I just did on my 350 for my 70 SWB truck about A month ago and it worked great. You do need the distributor housing to block off that oil passage when priming.
Gary
Old Mar 16, 2005 | 12:40 PM
mandm1200's Avatar
mandm1200
I called a couple of slavage yards. The ones that had an old distributor want $40. Guess I'll give ebay a shot, if not I'll have to order in the priming tool. Autozone shows the loan them, but the only Autozone in my area does not have one (and most of the other tools they list on the web site).
To Problem With Priming The Engine With Oil
