Please help! Why headlight opens up when car is turned off
http://www.zip-products.com/Zip/prod...A29A415D04C757
http://www.zip-products.com/Zip/asse...ges/M-3105.JPG
Hey.........I need one of those!!
Eddie
vacuum from creeping back and sucking the headlights up once the
engine is shut off. The check valve is most likely bad.
stored in the tank from sucking air during periods of low vacuum in
the manifold. The headlight actuators require vacuum to pull up and
vacuum to pull down. A leaky check valve would prevent them from
moving after the car is off. Am I missing something here ?
This is Lenny's second thread on this. I posted my guesses in the first.
I'll copy it here:
So, the lights are down - then when you turn the engine off,
the passenger side pops up ?
I'd say one of two issues:
1 - Someone named Bubba worked on the vacuum headlight
system and mucked it up.
2 - The vacuum relay has a leak to the UP side of the vacuum actuator.
Hmmm - maybe 3 :
There is a vacuum over-ride switch under the steering column.
This is used to hold the headlights in the up position when turning off
the engine. It's a little black **** that you push
up and down. Mine was snapped right off. Check it out.
Oh yeah - welcome to the madness !!!
$50 on eBay for an electric vacuum pump is the first investment you should make if you have ANY vaccum problems on an old Vette. You'll wonder how you worked on the system without one.
