And a few other things. I believe our mechanic was switching the cam, but not positive.. he told us when he is done, it should be in the 500 HP range, and what I wanted to know was what would be a good sturdy Transmission for this. The old one was a Muncie 4 speed transmission. Would it be possible to put in a 5 speed that will work well / better?
I just recently put a 700r4 in mine wit a 2800 stall converter. It has a lower first gear than the turbo 400 and I still am basicly getting 2 more gears out of it than the original.
If you want to go with MT, go with the TKO. If you want to go with AT, the TH200R4 is a great choice (but make sure that you get a "built" one.. The gear ratios on the TH200R4 are probably the best on any AT and they eat up less HP than TH700R4's and TH400's. They are also lighter and bolt right to the stock crossmember. It's a bolt on swap... My 200R4 is rated 800 HP. It's built by Art Carr's business (California Performance Transmission)
