Quick outside door handle question
Old Mar 16, 2005 | 01:03 PM
twistdpair's Avatar
twistdpair
Default Quick outside door handle question
Do I really need to the rubber door handle gasket? I am replacing my driver's side with a repro. I pulled off the original, and it didn't have the gasket. In addition, the repro I got from Eckler's doesn't have the gasket.
Can I just seal it up with something else, or do I need to order the gasket? I'm not going for an NCRS car.
-Corky
Old Mar 16, 2005 | 01:06 PM
guppie's Avatar
guppie
St. Jude Donor '08
gaskets are seperate order piece. I would put the gasket on but that's just me.
Old Mar 16, 2005 | 01:07 PM
GTR1999's Avatar
GTR1999
-Corky
I would use one or make one. Did you see if Ray (Corvette center)has one he's in you backyard?
Gary
Old Mar 16, 2005 | 01:39 PM
twistdpair's Avatar
twistdpair
Yeah, I think I'll call Corvette Center first. If they don't have it, I'll fashion one somehow. It's supposed to be nice this weekend!
Thanks guys!
Corky
Old Mar 16, 2005 | 02:21 PM
codestar7's Avatar
codestar7
Default Handle
Without the gasket the handle is just one more "Clunk" On return from opening. Rubber cushion it.
Old Mar 16, 2005 | 04:58 PM
ksbunting's Avatar
ksbunting
If for any reason your door handle should loosen up and slide around slightly, without a gasket it would scratch your paint, with a gasket you would have some protection between the door handle and the paint. Not sure what year car you are refering to but if you are going to the trouble of replacing the door handle you may as well replace the gasket as well. The gasket is not an expensive part.
To Quick outside door handle question
