Anyone using an O2 gauge...?
Old Mar 17, 2005 | 04:26 PM
1970-Bronze's Avatar
1970-Bronze
Originally Posted by BlackRat
Ok I don't want to high jack this thread but can somebody give me some detail on how an O2 sensor helps in tuning the car? How and where does it mount? What would be the purpose of an inside the car guage?
Black Rat,
You mount the O2 sensor in the collector to monitor the A/f ratio.
This allows you to set your idle, WOT, parital throttle - A/F for maximum performance.
Old Mar 17, 2005 | 04:54 PM
Brettmc's Avatar
Brettmc
Originally Posted by zwede
Widebands use what is called a "nernst cell", or "pump cell". At the risk of simplifying, the basic operation of a wideband is this:
Inside the wideband sensor is a regular narrowband element. The pump cell has the ability to "offset" the NB. So instead of switching hi/low at 14.7:1 (lambda 1.0), the pump cell can make it switch either at a higher or lower lambda. The amount of offset is controlled by how much current you feed into the pump cell.
The controller monitors the NB element and adjusts the pump cell current to make the NB element switch back and forth. The controller than looks at how much pump cell current it has to supply and calculates what lambda that represents.
In addition, a WB sensor has a fairly narrow heat range it works in so the controller also monitors and adjusts the heater element.
I WAS thinking of buying one to play around with...
Brett
Old Mar 17, 2005 | 04:59 PM
cbr900son's Avatar
cbr900son
Originally Posted by jimvette999
Two...one for each bank. Indispensable for tuning. I just wish they were wideband.
Jim
OFF subjext but what steering wheel is that? Looks nice
Old Mar 17, 2005 | 05:50 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I understand the theory. If you buy the single wire one from Summit how do you use it?
Do you tweak the carb until you have the gage is lighting up half the lights (in between lean and rich?)
Since it is a narrow band it will toggle from rich to lean fairly easy so if you hover in the middle it should be stoic right?
I was thinking of putting one in both sides and putting a switch on the gage. I am thinking of hiding the gage in the top of the park-brake console under the cushion so it is out of site most of the time.
Old Mar 17, 2005 | 06:27 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i wonder if there is any problem to put together a temporaory setup that you could just shove up the tailpipe and move from vehicle to vehicle?
Thats where the expensive emissions machines measure it.
Old Mar 17, 2005 | 06:32 PM
Duke94's Avatar
Duke94
Innovate Motorsport sell the tail pipe adaptor too. 75 bucks
Old Mar 17, 2005 | 08:35 PM
Mike Mercury's Avatar
Mike Mercury
in the voice of Darth Vader... "Impressive"
Old Mar 17, 2005 | 10:10 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
I'm using an Autometer sensor and gauge. Gauge is mounted in the clock space. Tuning is is easy. Unlike some others, I feel that the narrow band is a decent tuning tool. It seems the closer I tune the system the more stable and reliable the gauge reads. At idle it shows very stable at 13.5, at part throtle 13, at WOT 12, and at highway cruise 15.5. All the readings I intended to achieve.
Timing, carburator calibration, and vacuum all affect the reading.
Old Mar 17, 2005 | 11:34 PM
454Can-Am's Avatar
454Can-Am
I put mine where the clock was........(the stereo has a digital clock in it-- so why have 2 ). I installed a 2-way switch (yellow) in the center of the console, so I can switch from one side or the other. Rick
Old Mar 17, 2005 | 11:54 PM
lostpatrolman's Avatar
lostpatrolman
http://community-2.webtv.net/MATTGRU...ing/index.html
Old Mar 18, 2005 | 08:24 AM
jimvette999's Avatar
jimvette999
got it from here...looks like it's been discontinued though...they have others
and thanks Mike Mercury
Old Mar 18, 2005 | 09:41 AM
ImBatman's Avatar
ImBatman
I saw this one on Summits site along with a $60 guage. http://store.summitracing.com/partde...=KeywordSearch
Is this one that some of you are using or planning to use?
Wade
