Heat shield with fiberglass spring ?
Old Mar 17, 2005 | 11:13 AM
bams12's Avatar
bams12
Default Heat shield with fiberglass spring ?
I am changing my old steel spring for a new fiberglass model from VBP. Can anyone tell if they bought or fabricated any type of a heat shield after this mod. I have the factory exhaust but have not installled it all together yet so I am unsure of clearances. Just trying to stay one step ahead and get the car on the road sooner than later. Thanx Brent
Old Mar 17, 2005 | 11:25 AM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I used the VBP heat shield. Do yourself a favour and either make the heat shield about 2" wider on each side or make sure your exhaust runs DIRECTLY under your pumpkin. The heat shield is just a rectangel of aluminum with five holes in it so it should be easy to fabricate. Most of the "factory" exhaust replacements are spread apart under the pumpkin and thus can then transmit heat onto the spring.
I also put a square of "zeroclearance foil" on my spring to reflect any heat that may have got to the spring.
Old Mar 17, 2005 | 12:30 PM
vettfixr's Avatar
vettfixr
My TRW spring came with a heat shield when I installed it many years ago. Haven't had a problem yet.
Old Mar 17, 2005 | 04:46 PM
enforcer's Avatar
enforcer
I used that cloth type header wrap on the pipes where they got near the spring.
Old Mar 17, 2005 | 05:10 PM
jake1's Avatar
jake1
Part # THE-11620 from summit, just put one on and works well and loks cool. (It's shinny to match the exhaust) you just need to take your time to get it around the curve nicely.
Old Mar 17, 2005 | 06:41 PM
Gordonm's Avatar
Gordonm
Maybe I'm pushing my luck but I have not had one in the 6 years I have had the VBP spring.
To Heat shield with fiberglass spring ?
