Which A-C compressor wire is ground?
Old Mar 17, 2005 | 03:53 PM
magicv8's Avatar
magicv8
Default Which A-C compressor wire is ground?
I pulled both wires out of the plastic holder without noting whether the LH (driver's side) or RH (passenger side) position was ground. I am not sure if damage will be done if connected backward, so if someone will look at their compressor clutch connetor, it would be a great help. Its a 60s-70s A6 compressor
Old Mar 17, 2005 | 04:53 PM
Tankers's Avatar
Tankers
Mine is on the passenger side, but I do not think it makes a difference
Old Mar 17, 2005 | 05:26 PM
ksbunting's Avatar
ksbunting
On my 68 coupe the connector for the A/C compressor has two wires : one dark green and one black. The black is the shorter of the two and is the ground. On my car it is on the passenger side of the connector and connects to the condensor maounting bracket. I am the second owner of the car and have had it since 1972 and there have been no modifications of any kind so I think this is the correct wiring setup. Hope this helps,
Kurt
To Which A-C compressor wire is ground?
