hood clearance
Old Mar 18, 2005 | 09:39 PM
tilyn62's Avatar
tilyn62
Default hood clearance
I need more hood clearance so I can get the hood latched. The air cleaner is a 2 5/16 element with a 14 inch round air cleaner. The car is a 1971 corvette 454 it has a L88 hood on it and it still won't shut. The intake is a dual plane like a weiand action plus with a 750 holley with choke. I need like another 1/4 of an inch to get it to latch correctly. There is no spacer.
Old Mar 18, 2005 | 09:44 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Have you tried a GM drop base filter base? Used on L-88's/LT-1's and the L-46?
Old Mar 18, 2005 | 09:52 PM
tilyn62's Avatar
tilyn62
Where exactly can I get this air cleaner the one we have on there is an edelbrock with about a 1 inch drop.
Old Mar 18, 2005 | 10:03 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Zips, Paregon etc. Most of the major vendors should stock them.
Zips Click Here
Old Mar 18, 2005 | 11:11 PM
MsVetteMan's Avatar
MsVetteMan
Edelbrock has a two inch drop one......look closer.........
Old Mar 18, 2005 | 11:14 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Advance Auto Parts has a 14 inch Holley air filter assembly.. The base is a 1 1/4 inch drop base. That assembly is a lot cheaper than all toe other drop bases available.. I'm using that drop base and it works great..
To hood clearance
