On The Front Page
Old Mar 18, 2005 | 10:30 PM
big632's Avatar
big632
Default On The Front Page
I was just told my car is on the banner of digital corvettes.com.I think it would be nice to have a c3 on the top of the c3 section etc depending on what section your in. Maybe someones car every couple of weeks. What do you think of that idea?
Old Mar 18, 2005 | 10:42 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Looks like it Mike......
Old Mar 18, 2005 | 10:44 PM
lostpatrolman's Avatar
lostpatrolman
WOW, there it is! Looks great!
Dang you Jughead, you beat me to it!!
Old Mar 18, 2005 | 10:46 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
congrats Mike Looks good
Neal
Old Mar 19, 2005 | 12:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Nice car!
I have a yellow '75 (I think) at the top of my page here....
Old Mar 19, 2005 | 12:46 PM
PRNDL's Avatar
PRNDL
Originally Posted by I'm Batman
Nice car!
Old Mar 19, 2005 | 01:15 PM
matchframe's Avatar
matchframe
I just saw the new banner...... looks great!
I think it is great that a C3 gets top billing on something! I wish that at least the C3 section here would show a C3!
www.bigdogvettes.com
Old Mar 19, 2005 | 06:38 PM
CrossedFlags77's Avatar
CrossedFlags77
It does...go up to the top of the page and by your name/private messages you can select what generation you want to automatically pop up. If you have C3 selected you see...
Old Mar 19, 2005 | 07:31 PM
big632's Avatar
big632
Cool , I just switched mine over.
Old Mar 19, 2005 | 07:43 PM
norvalwilhelm's Avatar
norvalwilhelm
You must be a little slow Mike. I saw that a while ago and thought Patric finally spruced up the page.
You deserve it.
Old Mar 19, 2005 | 08:59 PM
matchframe's Avatar
matchframe
Very Cool!!!!
I just switched mine over! Thanks!
Nice choice to represent the C3s!!
Old Mar 19, 2005 | 09:33 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Old Mar 19, 2005 | 11:26 PM
big632's Avatar
big632
You deserve it.
Im not told Im slow very often but in this case I agree.
Old Mar 20, 2005 | 12:53 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
I never get tired of looking at that blown 632.
Mike crate that motor out and I will see what it will run in my 2200 lb. 63
Old Mar 20, 2005 | 07:54 AM
big632's Avatar
big632
You would have a 6sec ride for sure.I will need your advice soon,Im installing a nos blower plate system right now with progressive controller and digital 7 boost retard ,my goal is 2000+hp.Do you think I can y my main fuel line up front so one of the main lines runs to the nos fuel solenoid .It would be run with the same pump that runs the carbs. It is a pe pump set at 40psi up front then reg to the carbs. I would not reg the nos plate so It would see 40 psi when the solenoid opens. Im thinking my pump is plenty strong?It would make for a much cleaner install.The pump is 660gph per hour at 40 psi.You sure are making quick work of getting that car ready.Got the itch?
Old Mar 20, 2005 | 10:24 AM
69 N.O.X. RATT
2000 hp, wow, talk about having the itch. I have no problem with the high pressure NOS fuel side, but remember you need to send the fuel through a regulator to compensate for pressure changes (G-forces) through the run. I know you know this and are probably slapping your self in the head going duh. It sounds like you have plenty of pump so that should not be a problem.
Most of the guys I know are not a fan of the progressive controllers. They flutter the solenoid and some guys do not like that. I imagine you are looking to control the power of that beast when you launch it on the blower and bottle. A lot of guys are pulling a bunch of timing at the launch and then feeding it back to the motor during the run via one of the 7531 MSD boxes.
With the amount of power you are looking to make I would consult an expert, you miss the tune and you will have some engine damage. No doubt for parts and great advise give my buddies over at nitrous supply a call (714 373 1986). Ask for Mike Flynn and tell him you are a friend of mine. They will get you all the parts for the best deal around. These guys really know their stuff; however for what you are doing you need the top guy (as far as tuning) around and that is Jeff Prock at Applied Nitrous Technology. I do not have his phone # but you can find it as his web site. If it is possible to get 2000 hp out of your set up he will know how to do it.
Good luck Mike
Old Mar 20, 2005 | 11:24 AM
big632's Avatar
big632
Good luck Mike
Thanks john. The engine wo nos is at 1680 hp. I was going to add a 200 to 400 under carb plate system with the big controller. Iam already pulling timing in first and would inject the nos after first gear at 25 percent ramping up to 100percent in 2 seconds.That way a overly taxed chassis is not hit so hard to cause wheel spin and loss of control. I will have a safety switch that shuts down nos flow if there is a fuel problem. This is run with 114 gas too. I will back off the timing at the same time nos is added by 6 degrees bringing it back to 26. I will also start with the 175-200 pills to see how that works.I also have a set of beadlock wheels being made to add some stability at the high trap speed.Let me know how your first outing goes with the new ride.It should launch hard.mike
To On The Front Page
