There's no way back now
I only work on the frame outside, not the rest (fabricating stuff) but my new shop is going steady...a couple more weeks and it'll be finished.
I like those allen head fasteners but are they enough to hold on the front end at hi speed? Looks like it could use some cross bracing?
Good luck.
cardo0
Again I still see the spring pocket.
Wife is calling for supper. I will be back
I cut off almost half the pocket on the outside (it's angled outward), it was not just a little piece.
My shocks will sit much closer to the spindle than yours, it clears just fine (I installed a lower arm w/ the shock in place, there's plenty of room)
It will look like this:
See where that "tower" for the shock goes into the otuside of the frame? That will go straight over that upper pocket area. No need to cut it out, it won't do any harm there and it will be stronger than stock. Under that plate that I welded on there's also more metal, there's a "beam" that i welded on the inside and it's double walled.
thanks - Bob
Regardless of what you do put twice as many lights as you feel you will need and lots and lots of outlets. I put alot of outlets in the ceiling too so I can plug in directly overhead of most jobs.
I will put a 4 post lift in it and maybe a chain hoist. Lighting & outlets are not a problem I'll make sure there's plenty of them and a lot of high intensity lighting, have that in my other one as well (on one side only) The compressor, blasting cabinet and other stuff will stay in the other shop, I'll just pull an air line to the other shop (they are reasonable close to each other & I won't hear the compressor here and the blasting cabinet is heavy so it will stay where it is) so this one will be for building the car & parking the truck, the other one will still be the messy one
I'll have a good bunch of 400V outlets, I only have 2 in the other shop but I have a very long (25 meter) extension chord for it...so no problem there. For the pressurized air I'll have those nice reels hanging from the ceiling on each side and also an electrical reel (those things that wind themselves up).My goal with the car is keeping the glass stock and the rest not
I'm basically trying to get it as close to a full blown race car (GT1) as possible
It needs to be so brutal that little kids will run crying to their mommies
I feel haveing the car in a upper level which is still at ground level makes for a drier shop, no condensation. The basement is for storage, the tire machine the compressor and metal shelving for different raw material and car parts.
My shop is strickly my own, no storage, no mess.
I would like to see more pictures of the spring pocket and what you are doing.
It's about 525sq.ft..would have been way in excess of 750 if I had it my way, the side isn't the majority of the cost, the window frames, door frames, the hand baked stones and the roof construction are...all to keep it looking similar to the house...damn civil servants. But 2 2.5 car shops should be more than enough.
W/ storage I mean car parts, it takes up more space in pieces than as a whole
I don't have more pics but will next weekend or so. Easter means 1 more day of tinkering
I may remove that upper section of the spring pocket afterall and that stock reinforcement tab also and run a larger plate from the bottom up there into the "tower" that i still need to construct...damn you Norval now I have to chagne it again LOL
