Need some help ordering pistons!
I've had the block checked , cleaned, new cam bearings and frost plugs are also done. I have a forged 396/427 crank (internally balanced) and I have a good set of rods. The original pistons from this engine were not bad at all but I'm thinkin if I'm this far into this I should replace pistons as well.
As an added note I've also bought a new set of Edelbrock Performer RPM heads. They have a 110 cc chamber.
Here is where my concern is: I do street drive this car about 5000 kms per summer and since I'll be running pump fuel I'd like to keep the compression in the 9:1 range, or at least under 9.5:1.
This is the link to the set of pistons I'm considering.
http://www.jegs.com/cgi-bin/ncommerc...21&prmenbr=361
I just wonder if I'm on the right track here.
Thanks as always
Indynut
