T/T Column HELP
Old Mar 20, 2005 | 05:21 PM
Love My 72 and 77's Avatar
Love My 72 and 77
Default T/T Column HELP
Hi Guys I am working on a T/T out of a 74 Corvette, the pin that goes throgh the center of the shaft will not come out. I think someone jammed it down there hard enough to make it stay in the shaft. I tried tapping gently on the end of the shaft with the column hanging upside down with no luck. The tele shaft did move into the column a little. ANY SUGGESTIONS??
Old Mar 20, 2005 | 07:01 PM
Jim Shea's Avatar
Jim Shea
Did you try a magnet?
Next question. Why do you want to remove the pin? Does your T&T column not telescope?
There is a metal piece behind the pin that is offset. Pushing on the pin causes it to **** and lock the upper shaft from telescoping. Just off hand I don't have a clue as to what would be keeping the pin from not falling out of the upper shaft.
Old Mar 21, 2005 | 02:17 AM
Love My 72 and 77
Once again I am sorry for not makng my question clear. The tele is stuck in and will not tele in or out. The pin that locks the tele is stuck in the column.
To T/T Column HELP
