How do I remove the heater/AC box?
Old Mar 22, 2005 | 11:57 PM
VETDRMS's Avatar
VETDRMS
Default How do I remove the heater/AC box?
As the title implies I'm curious as to how I can go about removing the heating/cooling assembly as it is no longer hooked up and takes up space and adds weight.
Ideas?
Thanks!
Old Mar 23, 2005 | 12:03 AM
dwe's Avatar
dwe
see corvettefaq.com for some articles on replacing the heater core. It is pretty straight forward, you may want to fix yours up.
Old Mar 23, 2005 | 12:05 AM
VETDRMS's Avatar
VETDRMS
DWE: There is nothing wrong with it, I am referring to the complete removal of the system, big ugly box on the firewall included.
Old Mar 23, 2005 | 07:56 AM
GTR1999's Avatar
GTR1999
The box is 2 pieces that sandwich the firewall. You have to remove the lines,then there are screws going through the interior side to the eng side. You'll end up with a big sq hole in the firewall. You're going to have to remove the dash and gauge cluster.
Gary
Old Mar 23, 2005 | 10:47 AM
kdf1986's Avatar
kdf1986
From reading earlier posts on heater box replacement, it may make a difference if your car originally had air conditioning.
For air conditioned cars you have to take out the heater unit from the interior, removing the right side dash area. For non a/c cars you can do that from the engine bay.
Now you said you just want to remove the engine area heater cover. So I think that means you want to take out the heater core unit, and the engine bay cover completely, then replace the cover with a flat piece to make the firewall area cleaner. To do that you still have to remove the heater core.
check out this thread for some good tips.
http://www.corvettefaq.com/c3/C3CoreReplacement.pdf
kdf
To How do I remove the heater/AC box?
