LARS: Time question and clarifications needed!
Old Mar 24, 2005 | 09:29 AM
MsVetteMan's Avatar
MsVetteMan
Got it cleaned up hook........shoot it to me now!
Old Mar 24, 2005 | 10:59 AM
kdf1986's Avatar
kdf1986
This was a good thread to read on how to get the timing adjusted.
From reading it I have to go out and buy one of those timing lights that have the ability to set the strobe at 36 advance so I can set the timing right. Now I have the conventional style that does not have a preset.
kdf
Old Mar 24, 2005 | 11:50 AM
MsVetteMan's Avatar
MsVetteMan
Hey KDF...you can pick a timing parts up at just about any local parts store. I think mine was around 65 bucks or so........Great investment!
Old Mar 24, 2005 | 12:16 PM
A2Shark's Avatar
A2Shark
KFD -
Read Lars' paper on timing. It tells you how to set the timing when you don't have a timing light with a dial.
Old Mar 24, 2005 | 07:37 PM
conway62's Avatar
conway62
Lars,
So if I understand this correctly, on my MSD i would set it up with the 21 degree spacer and the soft springs. Then try setting my initial around 15 initial and go from there.
Old Mar 24, 2005 | 10:28 PM
MsVetteMan's Avatar
MsVetteMan
I believe one of Lars major points was screw the initial timing at idle.........
It's great to get you in the ball park, but it's more important at higher rpms, and that is what you should set it at.
On the springs, he said start with the softest........if your timing isn't coming in at around 36 degrees move and twist the distrib. to get it as close as you can, and if it still won't come in, change to a heavier spring mixes, until it does.
It works!
