Need some headlight help!
Old Mar 24, 2005 | 12:17 PM
75blackray's Avatar
75blackray
Default Need some headlight help!
Ok guys I know I'm not the only one with vacuum or headlight problems, but this one has me stumped and I suck at tracing the vacuum lines. Ok here is what happens.... nothing. Well the lights come on when I pull the switch but the headlights stay down. If i cut the car off and push the headlights up manually, when I start back up (whether my headlight switch is pulled out or not) the headlights suck back down. From what I get from the charts I've seen, I think that the vacuum lines on top of the actuator close the headlights and the ones on bottom open, at crawled under and looked at the actuator itself and the lines were connected. If anyone has been caught in the same situation or just could hint at somewhere to look it would be great. I know you guys will come through for me.
Austin
