HEI <again> Will it fit?
Old Mar 25, 2005 | 12:01 PM
OldSchool's Avatar
OldSchool
Default HEI <again> Will it fit?
Does the larger size of the HEI distributor with vacuum advance can clear the firewall of an early C3? Say a 75-78 distributor into a 71 vet?
Old Mar 25, 2005 | 12:02 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Im not intimately familiar with those years of vette, but I doubt there is any real firewall issues to contend with. How much room is there b/n the points dist. and the firewall now?
Old Mar 25, 2005 | 12:07 PM
OldSchool's Avatar
OldSchool
Engine is out.. And I can't remember..I have a new crate almost ready to go in..I want to use an HEI and convert to an electric tach.. Just wondering about clearances with that large base HEI..I remember having issues in a early Camaro...
Old Mar 25, 2005 | 12:15 PM
NHvette's Avatar
NHvette
I'm 90% sure the firewalls are basically the same.
I have both at home. I will try to look at each this weekend and post back here.
Old Mar 26, 2005 | 12:08 PM
tigers123's Avatar
tigers123
Default dist
Have 1974 with Accel Hei. Looks to be same size as stock gm and no clearance issues.
Old Mar 26, 2005 | 02:46 PM
bmizell's Avatar
bmizell
I am running a '74 350 with an HEI. It is a little tight but it will fit. Do not use the same wires to hook up the HEI. You have to by pass the low resistence wire that would normally go to the coil. Otherwise you will not have enough spark. I am still trying to get it all figured out. M A D Enterprizes in California has a web site and a lot of info. They sell a kit for $20.00. You can only contact them by phone. After 3 weeks I gave up.
Old Mar 26, 2005 | 02:52 PM
C3 Stroker's Avatar
C3 Stroker
I am running an HEI in my '69....plenty of room, no clearance issues.
To HEI <again> Will it fit?
