TKO 600 Neutral safety switch
Old Mar 26, 2005 | 04:28 PM
Engraver's Avatar
Engraver
Default TKO 600 Neutral safety switch
How is the Neutral safety switch (pigtail wire on the tko tailshaft) hooked up on the tko-600? This pigtail has a female plastic connector. Where do we find a connector to fit this?
Old Mar 26, 2005 | 04:40 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
I decided to just tie mine off and not use it for now. Mine is in a 70 so if I was to hook it up, I would have to run wires up to the clutch area and use the TKO switch rather than the old stock clutch switch. I opted to keep the clutch switch which I have grown use to anyway. Probably would have cut off the TKO connector and used somthing smaller, cheaper and more available.
Bullshark
