chambered exhaust w/headers?
Old Mar 27, 2005 | 02:51 AM
spyderdude's Avatar
spyderdude
7th Gear
Default chambered exhaust w/headers?
I searched, and this is probably a dumb question but I am curious, why won't the chambered exhaust just bolt up like the stock exhaust? or will a stock exhaust not bolt onto headers? My mechanical knowledge/experience is limited so would someone care to enlighten me? thanks, John
Old Mar 27, 2005 | 03:20 AM
olouieo's Avatar
olouieo
One of the reasons I can think of is that not all headers are the same size.
Old Mar 27, 2005 | 08:48 AM
Biker's Avatar
Biker
That's right. Headers are all different. Some have flanges that bolt to the stock exhaust, others don't.
Old Mar 27, 2005 | 09:02 AM
marshrat99's Avatar
marshrat99
Mid America Designs has a chambered exhaust that will directly replace stock. IE, will bolt up to your stock exhaust manifolds and replaces the existing pipes and muffler.
Old Mar 27, 2005 | 11:34 AM
onaqwst's Avatar
onaqwst
if u need a chamber exhaust, i have a full package never used that i will prolly be getting rid of to get small mufflers.......pm me if interested...they bolt up to dynomax headers...3" collector 3 bolt
b
Old Mar 27, 2005 | 10:54 PM
glen242's Avatar
glen242
Header collector location is different, depending upon brand. It is not that big a deal to get exhaust pipes fabed up to connect to the chambered. I used the MAD kit for chambered exhaust and headers. I received lenghts of straight pipe to bend for the exhaust pipe. Not a problem excepet for finding a local shop to do it. All I heard was "that would be illegal" because of my '76. Got some flex tubing, routed it the way I wanted, went to the SAME muffler shop and had them bend the rigid tubing to match the flex stuff I brought in. It seem as long as they are not doing the hook up, but just bending the pipe, they are not responsible. 3+ years and no problem. BTW, the car is exempt in PA because of the Classic plates.
Old Mar 28, 2005 | 01:02 AM
tigers123's Avatar
tigers123
Default chambered and shortie headers
I have a bone stock [no cam or big heads] in a 1974. I put mad chambered and shorty headers on. I think I have lost top end power. It's a seat of the pants feeling. I had to go to a exhaust fabricator to make all the hook ups.[including crossover] It does sound nice and it is loud, but no so much in the cabin. I can hear the radio just fine, and there is hardly resonance. It is a 2.5 inch system so I am not restricting it there. The only comment the fabricator made was you will be back for something else and I think he is right. They say that chambered can be restrictive and I think they are right. Comments?
Old Mar 28, 2005 | 10:55 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
I have a numbers matching 72 with a 4 speed, and as soon as I save up the money, I'm going for headers. With the cam I'm running on the rebuild, it would be foolish not to. Having exhaust fabricated isn't that expensive, or that technical. I plan on buying a 2.5 inch system from Rik's vet, installing up to the crossmember, and then taking it to an exhaust shop to hook it up the rest of the way. I bet it will cost less then a $100. and if it doesn't I'll figure a way to do it myself. One can make a lot of power on the exhaust side, and if you are going to do it, might as well make the most of it.
To chambered exhaust w/headers?
