Spongy Lifter ???
Old Mar 27, 2005 | 08:44 AM
superdad60's Avatar
superdad60
Default Spongy Lifter ???
I have a hydraulic setup
One... and just one rocker arms I am able to push down on the push rod side and it feels softly spring loaded. The others are tight and set.
This play is about 1/4 of an inch.
1. Can (should) a lifter get a feel of being spring loaded?
2. Does it firm up when oil goes into it or something?
3. Why only one and not the rest?
Thanks folks
Old Mar 27, 2005 | 09:28 AM
jimcork1's Avatar
jimcork1
Default Condition?
You didn't say if this is a new lifter just installed or a used one that has been run. If it is new and hasn't been primed/pumped yet this might be ok. IF it is an engine just shut down from lifting I would suspect a suck ball check valve in the lifter preventing it from pumping up and holding. If it is an engine that has been sitting for an extended time the pressure from the valve spring could result in a gradual loss of oil.
The only time it would be bad is if you just ran the engine for extended periods and shut it down, pulled the covers and then found it. Then you might have to replace it. But if you did you would really have to look at the base of the lifter for concave/convex condition to get a read on wear at the base of the lifter. It is not advisable to use a new parts with old parts. I have but that was on luckier days. You probably would want to try replacing 1 defective lifter but you might fail the cam later. In either case if you didn't try it you would go with new lifters and have to replace the cam anyway. So best of luck.. 99 nassau blue.
Old Mar 27, 2005 | 09:59 AM
superdad60's Avatar
superdad60
Right after running it and it has been in there quite a while
Thanks for the insight.
Old Mar 27, 2005 | 04:08 PM
superdad60's Avatar
superdad60
Couple more...
1. What happens if you readjust the rocker to compensate for the lifter failure?
2. Can you still drive it easily for transport?
3. What will be the long term results if you do this?
To Spongy Lifter ???
