Mystery Wire- see pic
Old Mar 27, 2005 | 09:51 AM
79vetter's Avatar
79vetter
Default Mystery Wire- see pic
This is hanging on the drivers side engine compartment by the brake booster. I don't see a place to plug it in. Does it Look familiar to you on a '79?
http://www.photohost.org/gallery/sho...cat=500&page=1
Old Mar 27, 2005 | 10:00 AM
Pete79L82's Avatar
Pete79L82
Look like the plug for the brake warning light. Should plug into the brake distribution block.
Pete
Old Mar 27, 2005 | 10:13 AM
Retro78's Avatar
Retro78
Pete
exactly what it is
Old Mar 27, 2005 | 10:18 AM
Schmucker's Avatar
Schmucker
And then his brake warning light will come on I bet, probably because the system wasn't properly bled at some point and the brake light wouldn't turn off.
Old Mar 27, 2005 | 10:58 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Pete
Interesting...where is that?
Old Mar 28, 2005 | 01:47 AM
c3 in hawaii's Avatar
c3 in hawaii
follow the brake lines from the master cylinder down towards the frame, you'll see the distribution box there.
Old Mar 28, 2005 | 01:51 AM
Twin_Turbo's Avatar
Twin_Turbo
it's a big brass thing with lines going in and coming out and has a white plastic socket in the middle...can't miss it. It's on the frame rail below the brake booster
To Mystery Wire- see pic
