Torque setting for valve cover bolts ?
Old Mar 27, 2005 | 02:44 PM
bams12's Avatar
bams12
Default Torque setting for valve cover bolts ?
Just installed new edelbrock chromed valve covers with felpro rubber gaskets. Does anyone know what the correct torque amounts for the screws would be ? Thanx Brent
Old Mar 27, 2005 | 02:46 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
between 15-20 INCH pounds...NOT FOOT POUNDS...if you do that much you will STRIP the bolt......I speak from EXPERIENCE!!!!
Old Mar 27, 2005 | 02:52 PM
bams12's Avatar
bams12
I have a foot pound wrench. Now I need an inch pound wrench ? Mo money,Mo Money........ Brent
Old Mar 27, 2005 | 02:58 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
well 12 inch pounds is a foot pound....do the math
But ive always torqued mine to around 3 foot pounds.
Old Mar 27, 2005 | 03:50 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Not a whole lot at all. That's why you see some guys use the wing-type bolts. Hand tight, just enough. You'll know if they're loose.
Old Mar 27, 2005 | 05:17 PM
redvetracr's Avatar
redvetracr
I always torque mine to the "snug" setting on my torque wrench (my arm)..................redvetracr
Old Mar 27, 2005 | 06:05 PM
luerja's Avatar
luerja
here's more spec's
http://www.gearheadracing.com/Refere...eSpecChevy.htm
In case you do something else in the future
Jim
Old Mar 27, 2005 | 06:22 PM
stingr69's Avatar
stingr69
one half of one "grunt-pound".
You want it tight enough to seal but not tight enough to snap the bolts. when you feel the gasket compressing, you are there so only go a quarter turn or so farther. Check them all again after a few miles.
-Mark.
Old Mar 27, 2005 | 07:34 PM
Rockn-Roll's Avatar
Rockn-Roll
-Mark.
Are you sure it's only 2 snugs to a grunt. I was thinking it was more like 7 snugs to a grunt. Unless you meant a groan which I believe comes after a grunt. I mean, if you have already snugged the bolts then go back over to snug them again is it a grunt or a groan?
To Torque setting for valve cover bolts ?
