Brake light problem (please read this one)
It almost like the tail lights and the brake lights have changed jobs... or voltage anyway. My taillights function fine (come on when the brake pedal is pushed) but kind of dim. The turn signals function fine too, but also kind of dim. When I turn on the headlights (and taillights) for night driving the taillights are very bright, so bright that you cannot tell when the brakes or turn signals are activated.
Strange huh?
Now I have done many things to the Vette this winter ... one being transforming the automatic to a 4 speed, the dash was out the steering column was out too. one more strange thing is my tach acts flaky ( jumps around at low speed and never reaches higher RPM)
Before the winter I built a new tach filter and it seemed to work fine then.
is there something I could have plugged in backwards? Do I have a bad ground? a bad switch?
Where are the grounds anyway? any tips on trouble shooting this? Anyone got a good schemantic? mines pretty small print.
This is dangerous I almost got rear ended last night.
Can you help?Thanks,
John
1. Some kind of short in the turn signal switch wiring. The brake light leads go to the turn signal switch before heading to the tail lights, so problems here also affect the brake lights.
2. Tail light bulb inserted incorrectly into the socket, so that both silver bumps were in contact with one of the two contacts at the bottom.
In my case, I had both problems simultaneously, so tracking down the cause was a PITA.
Thanks for the ideas.
I felt it may be a ground also so one of my questions was where are the grounds? I do remember hooking up what I thought was a very small ground wire to the trans bolt and thinking "whats this one for?" I will double check the grounds at the tailights too but this problem is with both lights. The steering columm plug won't be easy but sounds like a possability.
Anyone else have some suggestions what I can check?
John
John
Or one of the bulbs has shorted out the filament from the dim to bright filament?
Good Luck.
Strange huh?
John
Well its fixed...
After a lot of studying of the schematics, tracing circuits, reseating plugs, adding grounds and inspecting sockets I discovered the problem...
Get this... The lamps where in the sockets backwards :o
I didn’t even know this was possible but it was. The 1157 lamp has two filaments and two contacts at the base of the lamp and uses the shell for ground. 1157 has two bayonets; one mid shell and one low on the shell. The socket has two slots for these to mount in than twist.
Foolproof right?
NOT! You can install the bulb wrong and the problem you get is the wrong signal sent to the wrong filament. Each filament has different lighting properties (one will be brighter)You know just when you think you know a little about Vettes they humble you to keep you straight
Thanks for all who responded to this thread.
John
Foolproof right?
John
Glad you got rid of your bug john...
