There is a great article about the complete exhaust system, from headers sizes, flow rate, X and H-pipes in the most recent HotRoding Magazine. Thought this was a good article because I am researching X pipe for my 71. And by the way just FYI, I was told that an H-pipe would be a bad idea behind the crossmember because anything more than 7.5" to 8"in of a gap would actually be worse than no pipe. An X pipe is the solution, just a bit more work, and the article said it will give you a HP increase by equalizing the system. Just FYI.
P.S. A weird fact about air and its actual mass from the article. 1 100ft square cube of air would have the weight of 38 tons! Whoa...
i was gonna say, but then i put on my thinking cap... which makes me real smart, and I checked out some blimp stats...
http://www.goodyearblimp.com/b_stars_stripes.html and I see that a 100X100X100 cube is actually about twice the volume of the goodyear blimp and the blimp isnt EMPTY, it is full of a gas that is lighter than air but still weighs something, and the blimp has a gw of more than 6 tons... so 38 tons is not unreasonable!!
I'm following the suggestions in that article also. The way I read it, it said that an H-pipe was about as good as an X-pipe and placement wasn't very important.
My big concern is that to get a system configured correctly, you need resonators just after the collectors. This would place them right under your legs or maybe the seats. (I would like to avoid side pipes due to the noise). Has anyone done this? Has anyone seen resonators that are just big, hollow chambers without anything in them?
Bottom line - it was an excellent article and puts away a bunch of myths regarding exhaust systems.
Is that the article by David Vizard in Popular Hot Rodding?
If it is it's an old article and there are things in it that are misleading and or contradictory. I have his book where all the information comes from. And it's good.
He says that the exhaust design contributes 100 times more to the intake cycle than the intake manifold design, but then goes on to say that primary tube equal lengthness in un important.
Hmmmm
He mentions that the degree to which the tubes are equal isn't that important as supported by actual performance figures. If you think about it, a few inches here or there wouldn't be measureable in terms of performance. He did make a comment that I think is very interesting about manufacturers who claim to be able to make tube lengths equal to within .5 inches. Where do they meaure from when the tubes curve around? The middle of the tube, a line on the outside, etc.
I do like the picture of the Vette exhaust that was put together for a 700hp NA small block. I wonder where that resonator came from???
Hmmmm
That's the one. He explained that equal tube length didn't have a substantial effect on power but the collector length could make quite a difference. The resonator info was news to me. I'd like to see more info on that.
FUNNY, I was told by 3 exhaust pros that an X-pipe on a C3 is No Good or Not as good as an H-pipe because it's too far back from the collectors to be effective.
I see what you are saying and I suppose it does make sense.
One thing I do know is that when I went from very unequal length headers to equal length headers it became very easy to tune my carb. Before the idle screws made no difference, now they are nice and sensitive.
Ed of Headers by Ed makes this point. He also is a big proponent of equal length primaries, at least within 1/2". The reason for this it that then all clyinders are getting the same mixture at the same RPM. With unequal length headers some clyinders are lean, some are rich, making it hard to tune and while it doesn't effect the power much it matters when you start running Nitrous. That lean clyinder is the first to go boom.
As far as measuring primary length, comon it's not that hard
Hmmmm
That's a pretty strong statment. I'd certainly agree that it has a greater effect, but 100 X is a lot. Does he substantiate the claim?
