Easy noob question - vacuum
Old Mar 29, 2005 | 10:59 PM
twistdpair's Avatar
twistdpair
Default Easy noob question - vacuum
When checking vacuum (78 L-48), what should the pressure be?
Thanks,
Corky
Old Mar 29, 2005 | 11:00 PM
twistdpair's Avatar
twistdpair
Engine vacuum, that is...just to clarify
Old Mar 30, 2005 | 02:13 AM
Z-man's Avatar
Z-man
Proper engine operation should result in an even vacuum reading from 15 inches to 20 inches of vacuum with 15 inches of Mercury being more appropriate for high performance type engines. 10 inches would be on the low side...
Old Mar 30, 2005 | 08:03 AM
gerry72's Avatar
gerry72
For a properly tuned L-48 at idle, you should see 17 to 20" hg. Variations can be attributed to ignition timing, cam timing, cylinder pressure, and carb adjustment just to name the usual suspects.
Old Mar 30, 2005 | 11:41 PM
twistdpair's Avatar
twistdpair
Thank you.
-Corky
To Easy noob question - vacuum
