Did I damage a caliper piston?
Old Mar 29, 2005 | 11:23 PM
mark79,80's Avatar
mark79,80
Default Did I damage a caliper piston?
I recently installed rebuilt front calipers and new pads. Because I
overdo things I decided to pull the pads and degrease the rotors and
pads one more time. I used sheet metal retainers to hold
the pistons in place.
When I went to reinstall the pads I could not get one in place. I
noticed that one piston had turned a bit on an angle so it was stuck
and would not retract. I used a screw driver to pry against one side
of the piston to get it straight so it would retract.
Question: Did I damage the piston or seal so I am likely to get a leak?
Old Mar 29, 2005 | 11:26 PM
wombvette's Avatar
wombvette
Shouldnt be a problem.
Old Mar 30, 2005 | 12:19 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
If the piston came too far out of the bore there's a chance that the lip seal got twisted over and might leak. How far out was it and how easy was it to push back in? O ring seals wouldn't be a problem, tho.
Mike
Old Mar 30, 2005 | 06:24 AM
mark79,80's Avatar
mark79,80
Piston was out about one half inch. Once I aligned it by pushing on
the side that was sticking out further, it went back in easily.
Old Mar 30, 2005 | 10:50 AM
jimcork1's Avatar
jimcork1
Default Leaking?f
If it is stopping ok and not leaking drive on..
To Did I damage a caliper piston?
