Center console guages(size)autometer
Old Mar 30, 2005 | 07:56 AM
PatsLs1vette's Avatar
PatsLs1vette
Default Center console guages(size)autometer
Im replacing all my center guages with autometers to match my speedo and tach but what size do i need.Im going to englishtown in a few weeks for the swap meet and i want to pick everything i need up there.I thought it was 2 1/8 but cant remember.
Old Mar 30, 2005 | 08:24 AM
jetmech's Avatar
jetmech
I installed the sport-comp in my 79. Used the 2 1/16 size. Hope this helps.
Old Mar 30, 2005 | 08:37 AM
Jclgodale3's Avatar
Jclgodale3
yep...2 1/16"
Old Mar 30, 2005 | 09:50 AM
GATOR454's Avatar
GATOR454
Pat,
I'm going to install 2-1/16" gauges in my console too. I am going to eliminate the clock since my head unit will have one. I'm also planning on adding some switches to control various things and replace the useless warning lights with LED warning lights for low oil pressure, high coolant temp, low fuel and alt.
I made a template to cut an aluminum cover that I'm going to laminate with walnut veneer to match my Deluxe interior, but it could be kept bare or painted.
Here is a JPEG of the template:
The inner circle is 2-1/16" diameter and the outer circle is the 2-13/32" existing gauge opening. The upper tab has to be cut off in order for it to clear the wiper switch housing, and the lower tab can be bent around the bezel radius or cut off.
If you want it, I have the drawing in PDF (so you can print it to scale) or the AutoCAD drawing If you have AutoCAD and want to move things around. Just P.M. me with you E-mail and I will send it to you.
David
Old Mar 30, 2005 | 10:49 AM
PatsLs1vette
Thanks guys gator im gone to eliminate the clock too and get a air fuel ratio guage instead.
Old Mar 30, 2005 | 12:53 PM
mrtroutjedi's Avatar
mrtroutjedi
thats what I did too
Old Mar 30, 2005 | 01:10 PM
73 Vet's Avatar
73 Vet
Originally Posted by GATOR454
Pat,
David
David,
I've been contemplating this myself. May I ask, how is the aluminum cover attached to the existing panel, and, what are the tabs you mention? Are they existing, or a part of the new cover.
Thank you,
Michael
Old Mar 30, 2005 | 01:27 PM
GATOR454's Avatar
GATOR454
I haven't decided how to attach it yet. I am either going to epoxy or screw it on. The tabs are the areas beyond the dashed lines. The area above the upper dashed line is part of the existing bezel but is under the wiper switch/vent housing. Once I made the cardboard template I realized that it would have to be cut off so that there would not be any interference. The area below the lower dashed line is the part of the bezel that angles back towards the radio. If I can get a good looking bend then I will keep it. If I cant then I will just cut it off.
Old Mar 30, 2005 | 01:47 PM
73 Vet's Avatar
73 Vet
Thank you David. So, it will attach to the face. Can you send it to me in PDF? dobeshmc@bp.com
Old Mar 30, 2005 | 02:37 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
I put in 2-1/16" gauges and eliminated the clock too.
Here's how mine came out:
(sorry about the stereo wiring hanging out, still haven't finished that either!) DOH!
Old Mar 30, 2005 | 03:26 PM
timrb73coupe's Avatar
timrb73coupe
Please also forward a copy of the PDF to me boyle.tim@gmail.com
I currently have my center cluster out and this is a thread i will be following closely.
To Center console guages(size)autometer
