Oil Cooler
Old Mar 30, 2005 | 03:50 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Oil Cooler
Installing an oil cooler on the 454. The kit I bought was not specifically made for the Corvette. It has hard lines that won't fit. Can I just cut the hard lines where I need them and clamp-on some flexible black hose? If so, are there pressure issues (hose or keeping the lines clamped on)?
Old Mar 30, 2005 | 05:59 PM
chris75stingray's Avatar
chris75stingray
you should be able to use regular hose and clamps, just like on an automatic trans cooler.
Old Mar 30, 2005 | 06:08 PM
redvetracr's Avatar
redvetracr
I wouldn`t use a hose clamp on my car.....your oil pressure is what ??60lbs and an auto trans is 7-10 lbs..........
...redvetracr
Old Mar 30, 2005 | 06:21 PM
Wrencher's Avatar
Wrencher
Default Hoses...
I just did this on my Corvair. I mounted a remote cooler w/fan, bought bulk pressure hose, 6 AN fittings for each end and it came out great! Cost me around $100.00 dollars for hose and fittings.
If you use your existing lines, use a flaring tool to make a 'fat' spot right near the cut end to hold the hose when you clamp it on. Not as good, and not my preference but you could probably get away with it.
Hans
Old Apr 1, 2005 | 07:08 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I had a friend that used hydraulic hoses from a farm supply store .... seamed to work OK. Didn't leak and were oil resistant.
Old Apr 1, 2005 | 08:43 PM
70_Shark's Avatar
70_Shark
I ordered special 300psi x 1/2" ID(250psi specified by cooler manufacture)hose from Napa. Though it is red. Cooler fittings are 3/8"? to 1/2" barb. Works fine. Someday everything goes AN, when I win the lotto.
To Oil Cooler
