Started replacing the Master Cyl.. (pics)
Old Mar 31, 2005 | 07:39 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Started replacing the Master Cyl.. (pics)
Out with the old
prepping the new
I already bench bled it, and I hope I did it right. Normally its just push the piston till fluid comes out of both inlets right?
I bolted it up this afternoon and tomorrow morning I'm gunna start the full system bleed
Old Mar 31, 2005 | 07:42 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
replaced mine a while ago.. One of the easier jobs that I've done on the Vette.. I was surprised how little work it actually was..
Old Mar 31, 2005 | 07:57 PM
Corz's Avatar
Corz
it was pretty easy, I've done it before on a PB car.. just getting 35 year old brake lines off werent so easy
Old Mar 31, 2005 | 08:05 PM
kdf1986's Avatar
kdf1986
Corz,
How difficult was bench bleeding the master cylinder. On my 72 I have a very spongy brake that doesnt work until it is almost to the floor.
I am planning on replacing the rubber brake lines with braided steel and know I have to bleed the brakes. But I also want to bench bleed the master cylinder to insure that no air is in that also.
when I take off the master cylinder is bench bleeding it pretty easy? It looks like you have to check that no air is trapped in the forward cylinder is all.
kdf
Old Mar 31, 2005 | 08:06 PM
Roscoe's Avatar
Roscoe
Old Mar 31, 2005 | 08:10 PM
Corz's Avatar
Corz
Originally Posted by kdf1986
Corz,
kdf
I posted this to see if I did it right, all I did was clamp it in the vise grabbed a long center punch and just pushed the piston back till I had constant fluid pushing out of it since I didnt have the proper tools to do it.
Old Mar 31, 2005 | 08:14 PM
GrandSportC3
I was actually surprised how easy mine came off
Old Mar 31, 2005 | 10:03 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
nice primer gray paint job
Old Mar 31, 2005 | 10:14 PM
joe73vette's Avatar
joe73vette
I just replaced mine, too - is there any reason to save the old one? I don't need a core credit. Do people buy used ones? Joe
Old Apr 1, 2005 | 12:16 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
No. Don't re-bench a used master. This is something that's only done when installing a new one.
Old Apr 1, 2005 | 12:42 AM
Corz's Avatar
Corz
nice primer grEy paint job
It's krylon "steel grey" but thanks for noticing
Old Apr 1, 2005 | 09:11 AM
Tom454's Avatar
Tom454
The originals with the bleeders in them are "coveted" and can be re-sleeved if desired.
Bleederless non-originals are generally junk..... worth maybe a core charge if you paid it.
Old Apr 1, 2005 | 09:29 AM
MILO's Avatar
MILO
The last master cylinder I bench bleed, it came with two plastic plugs that fit where the lines attach. The directions said to push the plunger in slowly to about 1/4inch from bottoming out and slowy release. Repeat until you have no air bubbles appearing. Or if you have the plugs with the platic tubes, put the tube ends in the brake fluid and do the same procedure until no air bubbles appear from the tubes.
Old Apr 1, 2005 | 09:47 AM
Corz's Avatar
Corz
thats the thing, I had no plastic tubes or anything
Old Apr 1, 2005 | 09:55 AM
MILO's Avatar
MILO
Try going to the neighborhood auto parts and see if they have a kit laying around. Even if you have to buy a kit it's only a few bucks, not all stores have one to buy though.
Old Apr 1, 2005 | 09:58 AM
Corz's Avatar
Corz
alright
Old Apr 1, 2005 | 10:21 AM
GTR1999's Avatar
GTR1999
Forget the kit, go to NAPA. The M/C seat holes are metric and 2 different sizes. NAPA has short lenghts of metric brake conversion lines with the nuts that fit the seat. Cut the other end off and bend up the the lines into the M/C and you have a leak free seal and the best M/C bleeder there is.
Gary
To Started replacing the Master Cyl.. (pics)
Old Apr 1, 2005 | 11:40 AM
Corz's Avatar
Corz
I already bought the kit
oh well, I'll huff it over to napa after lunch.. what size pipe/ flare nut do I need?
Old Apr 1, 2005 | 12:47 PM
GTR1999's Avatar
GTR1999
They're metric and color coded. I don't know the size off hand, you're going to have to do some of the leg work kid
OK I'll help you out and give you a picture too.
Old Apr 1, 2005 | 01:32 PM
Corz's Avatar
Corz
I got it done I'm gunna bleed the whole system now
Thanks for the help
