I JUST FOUND THIS WEB SIGHT THIS LOOKS LIKE IT WOULD WORK WELL.PLUS YOUR NOT TAKING ALL THE VACUUM AWAY FROM THE ENGINE.I THINK.. ONLY WHEN I FLIP MY HEADLIGHTS UP THE ENGINE SEEMS TO STUMBLE A BIT MAYBE ITS NOT CONSTANT?http://www.vetteweb.com/tech/0408vet_c3lites/
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Those are Chris McDonalds, 69myway, lights in the vette magazine article. I think even Groovyjay has the lights in his vette with a video. The lights snap up and down. Another member, Aftershark, has them in his vette also.
If your Vette is stumbling whne you turn your headlights on you need to check your vaccum devices. Possibly the headlight relays or the actuaors are leaking. Block one side completely off and see if it improves. Do it on the other side. Is it the same or did it improve over the start state?
The relays are notorius for playing up. You can get new ones from gmpartdirect or rebuild them. Search for a norwegian? finish website that show how to rebuild them.
