Suspension Extension Bolt Installation
Old Apr 1, 2005 | 09:29 AM
Nygdup's Avatar
Nygdup
Default Suspension Extension Bolt Installation
I plan to tackle lowering my rear suspension over the weekend by use of extension bolts. Any suggestions or problems I might run into I need to be prepared for? It looks like all I have to do is simply set the suspension on jack stands to take the tension off the bolts, remove and replace. Am I correct?
Old Apr 1, 2005 | 10:08 AM
Dwaynes69BB's Avatar
Dwaynes69BB
From: I can explain it to you, but I can't comprehend it for ya.
Use a C-clamp to attach a small blockof wood near the end of the spring. Place your jack right beside the block of wood on the spring (this will prevent the jack from sliding on the spring). Then take pressure off the spring with the jack and swap in the longer bolt.
I'm runnin longer bolts in mine but really haven't lowered it any yet.
Old Apr 1, 2005 | 11:17 AM
Nygdup's Avatar
Nygdup
C-Clamps and a block of wood? I'd have never thought of that. Thanks for the suggestion.
Old Apr 1, 2005 | 12:14 PM
69monzaredbigblock's Avatar
69monzaredbigblock
If you have a rear sway bar you have to disconnect it to get the bolts out.
Old Apr 1, 2005 | 01:48 PM
glen242's Avatar
glen242
All of this information is available in a GM Shop Manual, Haynes Manual, Chilton Manual, etc. Any or all of these are a must investment if you are going to do any work yourself.
Old Apr 1, 2005 | 04:22 PM
Dwaynes69BB
He's right you know, thats where I got the hint about the block of wood and the c-clamp
Old Apr 1, 2005 | 04:36 PM
mandm1200's Avatar
mandm1200
I normally place the car's frame on the jack stands. That essentailly takes almost all the stress off the spring. It then requires only a light jacking of the spring to get the bolt and nut off. The downside to this is that another jack may be needed under the trailing arm to get the the bolt back in. I have a TRW spring and the angle of the bolt from the trailing arm to the spring was too great without jacking up the TA.
Old Apr 2, 2005 | 12:25 PM
Nygdup's Avatar
Nygdup
Tackled this project last night and it worked like a charm. Only real problem I had is that I didnt have 2 wrenches of the right size, but the channel-locks worked in the end.
To Suspension Extension Bolt Installation
