Spring Question
Old Apr 2, 2005 | 12:43 PM
XLAR8R's Avatar
XLAR8R
Default Spring Question
I put a new steel spring on my 79 almost two years ago and it made it sit a little high. I kept thinking it would come down some but it has not yet. Passenger side 28 3/4 from floor to fender and driver side 29 1/4. I even put the longer bolts (8 inch) on it and didnt make any difference. I have the nuts up as far as they willl go. Any suggestions ?
Old Apr 2, 2005 | 01:10 PM
GTR1999's Avatar
GTR1999
Bring the nuts down on the 8 bolts to lower it. Might have to go to the end,but leave a couple of thread showing. Aftermarket springs are just plain bad quality.
Gary
Old Apr 2, 2005 | 03:13 PM
KALAWAY's Avatar
KALAWAY
Gary
Yes, the nuts go down, instead of up. Before I got educated on the Forum, I assumed that if I raised the ends of the spring (nuts up), then the center and the body, would go down. Not so.
Old Apr 2, 2005 | 03:20 PM
mandm1200's Avatar
mandm1200
Like others have said, lower the nuts.
One way to look at it: by tightening the nut you are compressing the spring, loosening the nuts will relax the spring.
Old Apr 2, 2005 | 03:33 PM
XLAR8R's Avatar
XLAR8R
hmmmm, ok i'll try it again but i was doing it while i was doing the brakes and when i barely put the nuts on the body was even higher but i'll try it again, thanks.
Old Apr 2, 2005 | 04:08 PM
XLAR8R's Avatar
XLAR8R
OK, that worked, thanks guys. I feel like such a moron. But its still not good enough, guess ill have to try and find some longer ones.
To Spring Question
