SBC Heads
Old Apr 2, 2005 | 05:11 PM
Burnt71's Avatar
Burnt71
Default SBC Heads
I have found an old junk yard last worked in the early 1970s with alot of 1960s cars with the engines still intact. what are the most desirable SBC Heads and how can you tell what they are by looking at them ? Are there passinger cars I could get better heads off of for my stock 75 ? were most of the heads back then 2:02 valves ?
Old Apr 2, 2005 | 05:29 PM
SuperFast80's Avatar
SuperFast80
Look here for all the info - http://www.chevymania.com/
Old Apr 3, 2005 | 04:42 PM
Boofers's Avatar
Boofers
Good read here...
http://www.chevytalk.com/tech/engine/SBC_Heads.html
Old Apr 3, 2005 | 04:57 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
just remember, old engines (pre 74ish) dont have hardened seats. I ran into this issue with the 487x's i had for my car. One of the seats were so bad you could put the new seat in without cutting the old one out. Then you have to deal with heads without accessory holes too...
Old Apr 3, 2005 | 06:28 PM
fast idle's Avatar
fast idle
461,461x,462,462x,s.b.c. heads, these are the last three digits that are underneath the valve covers,all these are good heads.
049,781,820,236,241, all good big block heads.
Old Apr 3, 2005 | 06:47 PM
page62's Avatar
page62
This is only an advantage if you have a machine shop that can do the rebuilding job inexpensively. Otherwise, you're better off buying a set of new heads. Everyone around here knows which ones I recommend...
Old Apr 3, 2005 | 11:21 PM
markdtn's Avatar
markdtn
Some of the old heads like the "camel-humps" have value to restorers, but for today you are better off starting with Vortecs or aftermarket and going from there. They flow better, have hardened seats, and you won't have to put guides in them for a while.
Old Apr 4, 2005 | 01:27 AM
Solid LT1's Avatar
Solid LT1
By the time you make the investment into making old heads able to live on unleaded fule, you are better off buying Dart SR Torquer replacement cylinder heads or aluminum heads.
To SBC Heads
