Steering is darty
Old Apr 2, 2005 | 05:45 PM
Simul8's Avatar
Simul8
Default Steering is darty
Had the alignment done after rebuilding the chassis. Installed the new tires and took it for a ride, The steering still is darty.( If that's a word).
Any ideas???
Also the rearend sits 1.5" higher on the rt side. I used the original spring. I don't remember it being that way when I took it apart 2 years ago.
Old Apr 2, 2005 | 06:07 PM
bigvette1's Avatar
bigvette1
Default Alignment
Too much camber will cause "darty". Look in the book for VBP or get on their site and get the alignment specs - they work.
1.5" in the rear - something has to off in the spring bolt, or if somehow the t-arm is hung up on something not allowing it to drop.
Old Apr 3, 2005 | 12:43 PM
sparkys78's Avatar
sparkys78
6th Gear
VBP's alignment specs are great-I use them on all the Vettes I align. Toe the car in on the high side of the specs and it sure helps the steering without wearing the front tires. Also make sure the caster is maxed out-and do not set the caster higher on one side to compensate for road crown-this really makes the steering feel darty.
Old Apr 3, 2005 | 12:53 PM
carriljc's Avatar
carriljc
Default It was my rear tires....
Mine was darty and I couldn't figure it out, probably would still be trying to figure it out, but I blew out a rear tire and I had them replace both rear tires. .....and the dartiness went away....weird. Just sharing in case you can't find anything.
Old Apr 3, 2005 | 01:35 PM
Matt O's Avatar
Matt O
Try to find out why the car sits 1.5" higher on the rt rear.
To Steering is darty
