I finished gusseting the A-Arm mounts. Does anybody have pictures of how the gussets go on the motor mounts? I just wanted to make sure I don't have metal where something needs to be like steering linkage.
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
scroll through this post and look at the pics of TT frame you can see the gussets on the motor mounts and the front frame forks. I have not posted the motor mount and front fork gussets I added to my car. http://forums.corvetteforum.com/show....php?t=1023543
can't gusset the rear of the motor mount because of the steering box on the drivers side and it will hit the header on the pass side. I did not think of the steering system either but looking at it I think it will clear the gusset on the drivers side.
I will be dropping a Gen V Big Block in there, and plan on about 500 hp with about 525 ft lbs of torque. I wanted to make sure I had a good foundation for it to bolt to.
I still need to flip my frame over to finish welding the A-Arm gussets. Are the motor mounts hollow underneath? What if I welded a plate on the inside of the motor mounts to give it more area to hold onto the frame?
