alt or reg problem
Old Apr 2, 2005 | 07:58 PM
erock825's Avatar
erock825
Default alt or reg problem
does 70 have a external regulator i put a new alt on today and i am still having trouble with intermittent charging anyone had this before
Old Apr 3, 2005 | 06:24 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
I believe that your 70 had an internally regulated alternator. That started in 69. Chuck
Old Apr 3, 2005 | 04:39 PM
Boofers's Avatar
Boofers
With the car running (with RPMs above 1500) what is the voltage output of your alternator? It should be between 13V - 14.5V. A bad battery can bring this down, have you had your battery checked?
Also check your main electrical connections & grounds; the mating surfaces should be free of dirt & oxidation and should be tight.
To alt or reg problem
