Fuse panel/ wiring harness removal
Old Apr 3, 2005 | 02:44 PM
timrb73coupe's Avatar
timrb73coupe
Default Fuse panel/ wiring harness removal
b4 i resort to my BFH ... i have everything disconnected from the harness... both hex head screws out of the fuse box ... but the box does not want to come out quietly.
what else am i missing?
I have been patient so far and do not want to bubba it now ...
(but i am capable of that...)
Old Apr 3, 2005 | 02:49 PM
brooksman9's Avatar
brooksman9
St. Jude Contributor
What about the screw from the wiring harness side?
Old Apr 3, 2005 | 05:15 PM
timrb73coupe
which side?
the two i have removed are top right and bottom left ... flasher is top left...
Old Apr 3, 2005 | 05:27 PM
brooksman9's Avatar
brooksman9
There is a bolt that holds the harness in on the engine bay side. I know it will not come out without removing this bolt and unpluging the harness. Also think I read another post relating to this within the last several days. I'll look for it too.
Old Apr 3, 2005 | 07:52 PM
timrb73coupe
I found the bolt on the engine firewall.
If i am correct it is between the engine and forward light wire harnesses.
Yes?
this now rolls over to next weekend .. thanks for sharing your knowledge.
To Fuse panel/ wiring harness removal
