LS1 Custom headers: Part 1
Old Apr 3, 2005 | 10:41 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default LS1 Custom headers: Part 1
Started gathering all the parts to build a custom set of headers. Still need a donor set to cut up for spare tubing bends, but ebay is full of them and that shouldn't take to long. I decided to go the cheap route and buy a set of used headers off the forum. Since they are BB headers, the bends would be close. GM Racing also offers these nice 1/2" lasor cut flanges for $15. each. The pictures show the amount of bending or relocating that will be necessary to match the ports. The outside port will need to be sliced and rewelded, the inside will just need to be bent.
LS1 ports are 1 3/4" and the Headers are 1 7/8's. I will have out a way to reduce the tube at the flange. Is there tubing shrinker? Can I just split the bottom of the pipe and push it into the smaller hole? Advise needed.
Old Apr 3, 2005 | 10:58 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I built my own headers from Mandrel bends. you way looks much easier...
I would enlarge the flange enough so you can slip the pipe inside the hole then weld on the head side and grind flat. then braze the other side. Makes for a very strong forgiving connection.
Also that how headers by Ed does it and he knows his stuff.
Old Apr 4, 2005 | 09:15 AM
vettedan's Avatar
vettedan
Bud, It looks like your going to beat me to this conversion as well!!!
Dan
www.vetteworksonline.com
Old Apr 4, 2005 | 12:38 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Dan
The difference is "You can weld", I think I will just tack it and have someone else finish it.
Old Apr 4, 2005 | 02:53 PM
Scooter70's Avatar
Scooter70
While you're at it, make me a set too. 1 7/8" is pretty big, no? 427V8's way would seem to work, but I think that I would want a smaller tube size first, then step out to the big tube. I think that JohnB made his own stepped headers for his LS1 Monte SS. You might check out his site.
Old Apr 4, 2005 | 05:02 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Most of the aftermarket stuff for the LS1/2 is 1 7/8". I don't think it will hurt the torque, but it will breath.
427V8 had a great idea. Can I shrink the tubes.
Old Apr 4, 2005 | 06:57 PM
70 LS1's Avatar
70 LS1
My pacesetter's are 1 3/4". Those 1 7/8" should be good for you Buddy.
Old Apr 4, 2005 | 07:04 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Hey Bud sent you an e mail which should help out.
Old Apr 4, 2005 | 08:32 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Budman, I have never tried to do steel, but I have shrunk large diameter copper tubing (2 inch)with a spinning steel cone.
The steel cone creates friction and heats the metal tube as it spins. This allows the heated tubing to follow the descending diameter of the cone. In fact I have actually spun a copper pipe end closed using this method. jim
Old Apr 4, 2005 | 09:13 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Got it thanks.
Old Apr 4, 2005 | 09:15 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Sounds easy with copper, but I bet steel has a much highier bend rate. Pretty cool though.
Old Apr 4, 2005 | 10:41 PM
SteveG75's Avatar
SteveG75
I am more interested in where the exhaust flange is in relation to the crank centerline. Or to put it another way, how close or the LS1 exhaust ports to the BB ports in relation to the frame?
Old Apr 4, 2005 | 10:50 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
I'd offer my services if I wasnt on the other side of the country
Old Apr 4, 2005 | 11:04 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Since the motor is set in there like a small block, who knows. Vettedan has already mocked up the general area and says the driver side is fine, but the pass. side needs some work at the tranny. Maybe he will post a pic.
Old Apr 4, 2005 | 11:08 PM
vettedan's Avatar
vettedan
Bud, I'll post something tommorrow. I'm currently swamp!
Dan
Old Apr 4, 2005 | 11:11 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Dan
No rush, making money is more important. This header thing will take awhile.
Old Apr 4, 2005 | 11:15 PM
vettedan's Avatar
vettedan
Bud, You got me all getty about this so I bought some BB headers. I was hoping you would finish it. I think it will work.
Dan
To LS1 Custom headers: Part 1
