Steering Column
Old Apr 4, 2005 | 09:12 AM
Sevent8's Avatar
Sevent8
3rd Gear
Default Steering Column
Am looking for a diagram to rebuild the steering column completely. The assembly manual, haines, and other books do not show a complete rebuild (and I mean complete!). Does anyone out there have a diagram of the complete column including the bearings, shaft, bearing housing and such for the '78 Tilt/Tele column?
Chip
Old Apr 4, 2005 | 09:37 AM
jerryjfunk's Avatar
jerryjfunk
I remember there being a diagram somewhere in the tech tips section. Do a search! I know that my Haynes manual doesn't have a decent diagram in it.
Old Apr 4, 2005 | 10:38 AM
OldSchool's Avatar
OldSchool
Default Steering Column Diagrams
Jim Shea has posted many diagrams and troubleshooting articles on the corvette FAQ website
www.corvettefaq.com Look under steering on the left side.
Old Apr 4, 2005 | 02:47 PM
Jim Shea's Avatar
Jim Shea
This is a blowup of a 1976 T&T column. It does not have a dimmer pivot or dimmer switch on the column like your 1978 column has. Also, you do not have a shift tube (#64) since you have the finger lever to allow you to remove your ignition key from the lock cylinder.
http://www.corvettefaq.com/c3/T&TCol...cRev03FE04.doc
This page will help with the dimmer pivot, even though it is not a blowup.
http://www.corvettefaq.com/c3/T&TDis...age126FE03.doc
This page will help with the finger lever and the dimmer switch..
http://www.corvettefaq.com/c3/T&TDisasmInstrPage3.doc
Hope that these will help.
Jim
Old Apr 4, 2005 | 04:59 PM
Sevent8's Avatar
Sevent8
3rd Gear
Thanks all...that helped out tremondously!!
Chip
To Steering Column
