Source for 12" rear spring bolts?
Old Apr 4, 2005 | 09:43 AM
Grinchia's Avatar
Grinchia
Default Source for 12" rear spring bolts?
I have the 8" rear spring bolts with my fiberglass replacement spring, but rear ride height is (suprise suprise) too high. VBP has longer bolts:
http://www.vbandp.com/detail.aspx?ID=383
but $60.00 plus shipping for two bolts seems a bit silly, doncha think? Especially since the 10" blots are "only" $20 (plus shipping) for a pair
http://www.vbandp.com/detail.aspx?ID=443
Where might I look for 10 or 12 inch by 1/2 inch grade 8 bolts?
-Roy
Old Apr 4, 2005 | 09:47 AM
pws69's Avatar
pws69
-Roy
12" could create a very serious safety issue.
Old Apr 4, 2005 | 09:53 AM
lvrpool32's Avatar
lvrpool32
10" max.............even then those would be the first thing to hit the floor if you get a flat.
Mcmaster-carr is a good source for fasteners (10" type).
Old Apr 4, 2005 | 09:56 AM
74FLCONV's Avatar
74FLCONV
I purchased my Grade 8 8" bolts w/nyloc nuts from a local industrial bolt supplier (Yellow Pages: "Bolts") for less than $15.
However, as indicated above, 12" might be pushing it.
D. Ocean
Miami, FLA
Old Apr 4, 2005 | 09:58 AM
redvetracr's Avatar
redvetracr
have you considered letting your fingers do the walking?? as in the phone book under industrial supply?? or fastners....
....redvetracr
PS: John Deere has an amazing selection in their fastner book...
Old Apr 4, 2005 | 10:18 AM
Grinchia's Avatar
Grinchia
....redvetracr
I've been looking online (I live in a small town, and local options are sparse), found lots of bolts up to 8", but no bigger. I was trying to remember the name "Mcmaster-Carr", they have a great selection of goodies, I bought some bronze bushings from them before. I'll try them next.
If 10" is the biggest I can safely go, then so be it...I'll order some 10" ones.
Thanks all!
-Roy
Old Apr 4, 2005 | 10:31 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I have the 8" rear spring bolts with my fiberglass replacement spring, -Roy
which brand srping is it?
Old Apr 4, 2005 | 11:06 AM
NHvette's Avatar
NHvette
Roy, if in a small town in Iowa, then try the closest tractor supplier.
Chappel Tractor up near me carries lots of HD hardware.
Old Apr 4, 2005 | 11:31 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
www.mcmastercarr.com
10" long bolts 5/8" diameter, Grade 8 $10 each
1/2" or 5/8" diameter - both sizes fit
I think original is 1/2"
Old Apr 4, 2005 | 12:38 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Can I guess??
Old Apr 4, 2005 | 12:42 PM
Stewart's74's Avatar
Stewart's74
I did as others have.....contacted a local Industrial Fastener Shop. I got 2 8" bolts and locking nuts for under $10.
Old Apr 4, 2005 | 01:06 PM
mandm1200's Avatar
mandm1200
Originally Posted by 427V8
Can I guess??
I don't think you'll have to guess. They are going to post some results of their recent testing. I would be surprised to hear anything other than they have no issues with ride height and will not do anything about it. The test results were supposed to done by the end of Feb, might still be looking at data so it can look like there is nothing wrong with all of them. I won't buy another product from them until they admit there is a problem and come up with some sort of remedy.
There should be no reason to use 10" bolts. I had to use them to drop the car under 30". In my opinion that is too long and affects the safety ot the car. 12" bolts are insane, they be hanging way low.
Old Apr 4, 2005 | 01:59 PM
427V8's Avatar
427V8
IMHO 10" is a safety hazzard!
12" is stupid.
I'll be surprised if they post ANY results what so ever.
An I've quit caring
Old Apr 4, 2005 | 02:17 PM
Grinchia's Avatar
Grinchia
The spring is TRW, maybe 360lbs? I don't recall. I would rather have 6" bolts than the 8" I now have, but I'm jacked a long way up in the back, and I don't wish to return to the steel spring.
The tractor shop would have been a good idea, I have John Deer and Case III within 5 minutes of here. I just ordered from McMaster Carr though.
Old Apr 4, 2005 | 04:42 PM
Kid Vette's Avatar
Kid Vette
BINGO!!
Do yourself a favor and forget about the 10" and 12" bolts. Take the spring off and send it back for a refund. Then buy a composite spring from VBP. You'll have the height you want with 8" bolts.
Old Apr 4, 2005 | 04:55 PM
c3-4me's Avatar
c3-4me
Default Don't do it!
I seen a post where one of the memmbers took a turn too fast and the longer bolt actually shredded the inside wall of the tire!
I would do what you could to return the spring you got and buy the VBP spring. Mine was the right height with the bolts they sent.
Old Apr 4, 2005 | 09:43 PM
BigBlockk's Avatar
BigBlockk
Get a 3 foot peice of allthread and some nuts and washers.
BigBlockk
Later.....
To Source for 12" rear spring bolts?
Old Apr 4, 2005 | 09:59 PM
MIKER's Avatar
MIKER
Originally Posted by c3-4me
I seen a post where one of the memmbers took a turn too fast and the longer bolt actually shredded the inside wall of the tire! ...
That would be me!
Old Apr 4, 2005 | 11:17 PM
LFZ's Avatar
LFZ
10" bolts looked great on my car, but it was too close to the rim lip and tire...even with 17s. I didn't want to take any chances, especially with burnouts and taking hard turns. I took them off, and stuck my 8" bolts back on. 12" is probably not going to help since it seems that the spring is the case for riding too high.
Old Apr 4, 2005 | 11:25 PM
petronix's Avatar
petronix
Can't comment on what maximum length should be. Check www.fastenal.com for a location near you. The guys are great at the location near me, and they seem to have just about any fastener you might imagine and then some.
