Steering is screwed...
mind is the inner and outer tie rod ends. Steering box, control
valve, and the coupler could all be suspect, also. IMO, one inch
of play at the steering wheel is not terribly excessive. This tends
to rule out the box, valve, and coupler ... pointing back at a worn tie rod end.
Could also be a little of each adding up.
Ooops - almost forgot the idler arm, too. Usually not the first part to
wear down, but it could be fubar.
When I got home with the car I put it up on jack stands and carefully checked ball joints tie rod ends and bushings. Nothing was out of the ordinary until I checked the adjustment screw on the steering gear. I loosened the nut on the screw and gave the screw a turn. I got almost 3/4 of a turn slack. I don't think the gear had ever been adjusted. Having rebuilt a few of them and knowing how they work I drove the car for about two weeks making slight no pressure adjustments to the screw every two or three days. The darting around stopped after two or three adjustments and the car drove like it was supposed to.
I Check your balljoints too.
Besides the above posted recommendations- check the front wheel bearing adjustment, trailing arms, rear struts and bearings as well. These can throw you all over the road.
