75 rear wheel bearings ?
Bair's has done 3 of 4 of my C3's rear bearings. Do it right, do it ONCE
Basically, you can probably buy the tools and parts you'll
need for the same - maybe less than paying to have them done.
But, now you run the risk of doing them wrong and losing in the long run.
If you are mechanically apt, then I say read up on the procedures,
look over the diagrams and go for it. If you have a hydraulic
press (or can use one), you are half way there.
Check corvettefaq.com for procedures and diagrams. Pretty sure they have something there.
Hardest part so far was just drilling out the rotor rivets and that was relatively easy.
If I didn't need new spindles and was closer to FL., I would have sent them to Van Steel for rebuilding.
Mike
All in all, I think your plan works OK.
If you are not replacing the bearings yourself, don't even mess
with the spindles. That's what you're paying to have done.
I drilled a coupe rotors off myself last night. The stock rivets
were a piece of cake, but Bubba put a rotor on long ago. He used
5/16 hardened bolts with the heads ground down and the nuts
welded to the bolt. Lucky for me, he didn't have enough heat
to get the weld stuck to the spindle ... close, though.
Not only DO it, but gimme a minute and I'll mail ya my whole CAR to have IT done!!
One thing for certain - get t done. Nov '02? I guess? I was doing about 80 next to the magnet wall when the inner bearing on my more and more mutant '75 seized and cut through the spindle liek it was made of butter - without so much as a squeal.
It's interesting having your rear wheel and assembly pass you on the highway....
....looked like the space shuttle coming in on three wheels and suspension...
I was so worried I had somehow damaged my TD 12 bolt rear I spent nearly $4K having installed I spent the better part of another $4k having the whole rear suspension rebuilt. Really, there was very little damage to anything - idiocy is it's own reward....
Under $500 (or even $300!) for a hellish job like that is well worth it - take home from two overtime shifts? You'll be on it for a week - a good solid 50-70 hours. Of course you know you'll need the rear end re-aligned after that kind of disruption to the trailing arms, but that's just another $60.
sometimes it's good being a ex-mechanic!!!
After I got the spindles out, I polished the spindle area where the inner wheel bearing rides to make it easier to re-install the inner bearings and that made set-up a snap!!!
If you guy's decide to tackle your own rear wheel bearings let me know.... I can give you some help.
Gary
this "trick" was tought to me by a mechanic that used to roadrace corvettes in the early 70's....... so i trust his judgement.
