C3 Voltmeter
Old Apr 5, 2005 | 04:51 AM
73L82's Avatar
73L82
Cruising
Default C3 Voltmeter
When did they switch from an ampmeter to a voltmeter in the C3s? (1976 or 1977) I'd like to install a voltmeter where the ampmeter lives but have it look somewhat like it belongs there. So I figure I'd install one from whenever they first switched to have it match. I am aware of the wiring changes I have to make.
Old Apr 5, 2005 | 05:33 AM
DRL502's Avatar
DRL502
76 had a voltmeter, but it could have been 75 also, because it was 75 that GM moved to HEI ignition.
Old Apr 5, 2005 | 07:59 AM
markdtn's Avatar
markdtn
76 is first year for voltmeter. You can swap the needles to an orange one to make everything look similar. I have a voltmeter in my 69.
Old Apr 5, 2005 | 11:03 AM
mrvette's Avatar
mrvette
Another close match and easier to find is from an 80's pickup truck, same thing mechanically....even the print font saying volts is not so much differant...
GENE
Old Apr 5, 2005 | 11:15 AM
Vette Gator's Avatar
Vette Gator
Hmmm. My '76 has an ammeter. Wouldn't be the first non-year-correct replacement I've found on the car! As best I can tell, I have an early '76; maybe the change happened at the early-late division that year?
Old Apr 7, 2005 | 05:10 AM
73L82's Avatar
73L82
Cruising
Not to beat a dead horse, but like Vette Gator implied, could the early 1976 have ammeters and the later ones have voltmeters. I'm looking around and so far I've been told that 1976s only came with ammeters.
Old Apr 7, 2005 | 08:02 AM
mrvette's Avatar
mrvette
The chage came in '78, with the plastic dash panel,....
GENE
To C3 Voltmeter
