Zoops Instructions
Old Apr 5, 2005 | 08:53 PM
dsagers's Avatar
dsagers
Default Zoops Instructions
Probably shouldn't admit this one a public forum, but I like to read instructions before tackling a project.
Bought a set of Zoops billet brackets for the AC and alternator in my 81. The set was still in the vacuum seal attached to cardboard, but there are no instructions about where all the small parts go. Most of it is easy to figure out, but I have some left over parts, so I may have installed them wrong.
Anyone have instructions for installing Zoops brackets PN #8002?
Old Apr 5, 2005 | 10:23 PM
GDaina's Avatar
GDaina
I would venture a guess the left over parts are used in another application...could be a universal fit....just my guess...
Old Apr 5, 2005 | 11:24 PM
A C's Avatar
A C
Cruise-In II Veteran
I think George might be right. I installed their alternator bracket, and don't remember needing the instructions, but I am sure if you emailed them with your questions or called them they would answer.
Old Apr 6, 2005 | 09:13 AM
dsagers's Avatar
dsagers
Thanks for the comments.
I emailed them a few days ago, and no response...
Old Apr 6, 2005 | 09:32 AM
lvrpool32's Avatar
lvrpool32
All my pulleys and brackets are zoops.........theres not much to the brackets, 2 bolts that go into the heads, a collar for the bolt that mounts the alternator or sanden style AC compressor. Then there is an aluminum spacer (round tube) that goes between the bracket and the water pump. They do through ina couple of washers as spacers.
I would call Zoops with any questions, always found them to be helpful.
Nick
To Zoops Instructions
