my cats are red!!!!
Old Apr 6, 2005 | 07:10 PM
chris75stingray's Avatar
chris75stingray
Default my cats are red!!!!
i just got a edelbrock 750 on my 75 l48. i tuned it and took it for a couple of test drives. then i started seeing smoke that seemed to be comming from around the trans and then i started to smell fiberglass. it didn't seem that odd because i was sanding my car and maybe i just got some dust in the vents. then a lot of smoke stated to come up around the car and the tail pipes were really hot. so i looked underneath and was shocked. the catalytic converters were molten red.
at first i thought those $30 pieces of s*** were clogged, but there seemed to be good flow from the tail pipes.
i've read some posts on how a car running rich has hotter exhaust, so i tightened the mixture screws and they cooled right down.
so my car still smells like melting fiberglass and i have a c.d changer remote that sits almost directly above one of the cats and it MELTED into my carpet.
but everything is good know. shes running beautiful
Old Apr 6, 2005 | 07:21 PM
Pete76Shark's Avatar
Pete76Shark
If you want to cool down the exhaust temp you richen the mixture.
If you want to raise the exhaust temp you lean the mixture.
More gas = cooler exhaust temp.
Old Apr 6, 2005 | 08:28 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Exhaust gas temp yes.
But with the very rich exhaust, the unburnt fuel is burnt in the catalytic perverter. That can get the cats to over 2000 F. That IS hot enough to melt the ceramic part of the converter.
Don
Old Apr 6, 2005 | 09:33 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
If it melted your CD changer it very likely melted the ceramic perverter internals also..... that would explain why she runs great and why there's a lot of flow at the tailpipes...
hollow converter = good converter
Old Apr 6, 2005 | 11:18 PM
chris75stingray
hopfuly it hollowed. will save me the trouble of taking them off and doing it. i hope i pass emissions though.
Old Apr 7, 2005 | 10:36 AM
steves_77vette's Avatar
steves_77vette
I know how to fix that problem even easier.
Remove the Cats!
Old Apr 7, 2005 | 10:55 AM
flood's Avatar
flood
wow what a mod. Just richen the hell out of your carb and burn the cats straight thru. Emissions guys are happy cause you got cats and your happy cause there ain't nothin in em! win win
Old Apr 7, 2005 | 11:10 AM
jerryjfunk's Avatar
jerryjfunk
Old Apr 7, 2005 | 12:20 PM
Wrencher's Avatar
Wrencher
Technically right on a non-catalyst vehicle, but unburned (cold) fuel WILL get burned up in the cat, thus the high (red hot) converter temps.
I see this a lot with early Catalyst controlled vehicles that are modified. You mentioned an upcoming smog test, so your best bet is to get it pre-tested. That accomplishes a couple of things. First, it'll let you know if your cat (s) survived, which is a possibility, and you can fine-tune your mixture to (a) pass smog, and (b) not smoke your converter.
Even then, make sure your EGR valve works if you do any mountain driving, because a long pull up a grade will cause a rich mixture at a lower RPM (thus overheating the cat), and a good EGR adds burned (inert) gas to the intake charge, reducing the amount of total air/fuel volume in the cylinder and reducing the resulting cylinder/exhaust temps. Most replacement GM EGR valves come with a variety of orifices that apply to different calibrations, but I like to experiment with smaller discs to get good power while still meeting emmisions. That's critical here in CA where they check for Nox on a dyno, and they won't pass without the EGR working.
Get this resolved, or you run the risk of melting more than just a little carpet.
Hans
Old Apr 7, 2005 | 12:25 PM
Jeffski's Avatar
Jeffski
Don
Had this happen to another car I had with dual cats, I had one Cat only get super hot and it fried the internals, you may have a problem with E-test. Mine also started to rattle shortly after that, result of being cooked!!
Good Luck
Old Apr 7, 2005 | 03:41 PM
LemansBlue68's Avatar
LemansBlue68
Had an old van that the cat started to rattle on. A couple of well placed deck screws through the case and into the ceramic brick solved the problem without replacing the cat.
Best of luck,
Bubba
Old Apr 7, 2005 | 04:01 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Not true when it gets to the cats.
the extra fuel will first clog the cats, and then the cats act as afterburners. The additional fuel gets burned in the cats making them hotter and hotter. Cats have been known to burst, interiors can catch fire other similar problems. Also, never pull over to the side of the road and park over dry grass. The cats can cause the grass to catch fire and then your car will become a fiberglass puddle on the side of the road.
Old Apr 7, 2005 | 05:36 PM
Wrencher's Avatar
Wrencher
Default Doh!
[QUOTE=chris75stingray]i just got a edelbrock 750 on my 75 l48. /QUOTE]
Here I'm talking Q-Jet and you clearly state Edelbrock 750! The Carter AFB base carbs are even easier to work on.
Hans
Old Apr 7, 2005 | 07:30 PM
chris75stingray
i'm lucky i caught that before anything caught fire. i had to take the EGR off because it interfered with the carb linkage, but its next on my list to put back on.
emissions aren't untill june, but it was way below the standards last year so i think it will pass even w/o cats.
Old Apr 7, 2005 | 07:34 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Old Apr 8, 2005 | 11:19 AM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Uhhh -- you did put a plate to block off the hole, right ?
And it does have a gasket, and all is tight ??
Old Apr 8, 2005 | 08:35 PM
chris75stingray
of course ....
To my cats are red!!!!
